a timer that goes logic high or low every 15mins ( using tiny85 chip)
timtim1234
Joined Nov 30, 2023
246
First your hook your uno up load the code i posted then you hook the attiny as listed uno pin 11 to attiny mosi , uno pin 12 to attiny moso , uno pin 13 to attiny sck , uno pin 10 to attiny reset
Power and ground
Next you set the attiny as your board set chip attiny clock 8mhz bootloader you want then hit the burn bootloader
ohhh i thought you wanted me to unhook pin 10 i will try what u say will let you know
timtim1234
Joined Nov 30, 2023
246
nope same error :(
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x00
Failed chip erase: uploading error: exit status 1
be80be
Joined Jul 5, 2008
2,400
You probably bricked that chip you'll need a high voltage programmer to fix it
go to file then down to preferences click show verbose output during upload
and post that
It look like this but show you errors
Code:
avrdude: Version 6.3-20201216
         Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "/home/burt/.arduino15/packages/ATTinyCore/hardware/avr/1.5.2/avrdude.conf"
         User configuration file is "/home/burt/.avrduderc"
         User configuration file does not exist or is not a regular file, skipping
         Using Port                    : /dev/ttyACM0
         Using Programmer              : stk500v1
         Overriding Baud Rate          : 19200
         Setting bit clk period        : 5.0
         AVR Part                      : ATtiny85
         Chip Erase delay              : 400000 us
         PAGEL                         : P00
         BS2                           : P00
         RESET disposition             : possible i/o
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    12     4    0 no        512    4      0  4000  4500 0xff 0xff
           flash         65    12    32    0 yes      8192   64    128 30000 30000 0xff 0xff
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
           lock           0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           lfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           calibration    0     0     0    0 no          2    0      0     0     0 0x00 0x00
         Programmer Type : STK500
         Description     : Atmel STK500 Version 1.x firmware
         Hardware Version: 2
         Firmware Version: 1.18
         Topcard         : Unknown
         Vtarget         : 0.0 V
         Varef           : 0.0 V
         Oscillator      : Off
         SCK period      : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.02s
avrdude: Device signature = 0x1e930b (probably t85)
avrdude: NOTE: "flash" memory has been specified, an erase cycle will be performed
         To disable this feature, specify the -D option.
avrdude: erasing chip
avrdude: reading input file "/tmp/arduino/sketches/3A9C11F89B4B085F6A5A15D84FADD915/Blink.ino.hex"
avrdude: writing flash (456 bytes):
Writing | ################################################## | 100% 0.72s
avrdude: 456 bytes of flash written
avrdude: verifying flash memory against /tmp/arduino/sketches/3A9C11F89B4B085F6A5A15D84FADD915/Blink.ino.hex:
avrdude: load data flash data from input file /tmp/arduino/sketches/3A9C11F89B4B085F6A5A15D84FADD915/Blink.ino.hex:
avrdude: input file /tmp/arduino/sketches/3A9C11F89B4B085F6A5A15D84FADD915/Blink.ino.hex contains 456 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 0.36s
avrdude: verifying ...
avrdude: 456 bytes of flash verified
avrdude done.  Thank you.
be80be
Joined Jul 5, 2008
2,400
If you setup the chip to program and you do it wrong it flashes who knows what to the chip been the done that flashed th atmeg bootloader to a atiny
timtim1234
Joined Nov 30, 2023
246
just in case if it was bricked i tried another chip same thing :( if you know of some schematic diagram for a simple programmer i could make one. well if i have all the parts here
timtim1234
Joined Nov 30, 2023
246
also every website i lookup shows the same UNO to the tiny85 wiring. I check my wiring many times.
At this point, I am not sure what else to do
timtim1234
Joined Nov 30, 2023
246
Well update I have spent hours on this and still no luck same error I have tried everything I even went on the web and lookup the error and tried the "fixes" no luck. This is why I like hardware instead of programming..lol
anyway i don't know if I will order anymore "programmers" I don't want to have a pile of them here and not work..lol
I would like to thank everyone for helping :)
35,320
Welcome to the Arduino world!
You need to know and understand how the Arduino platform works. In order for the Arduino to run it has to have a working program in the first place.
This is why I use the AVR Pocket Programmer. I run bare bones code directly on the ATtiny85.
I don't use Arduino.
timtim1234
Joined Nov 30, 2023
246
Ya, I can see why you do now! lol ohh well it is what it is :)
be80be
Joined Jul 5, 2008
2,400
I used arduino without the cores it let you write code in C and load hex files but thats been while back
If you do what o ask in post 103 we could probably get you going.
timtim1234
Joined Nov 30, 2023
246
here it is
"C:\Users\Admin\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/bin/avrdude" "-CC:\Users\Admin\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf" -v -v -v -v -pattiny85 -cstk500v1 -PCOM6 -b19200 -e -Uefuse:w:0xff:m -Uhfuse:w:0xdf:m -Ulfuse:w:0xe2:m
avrdude: Version 6.3-20190619
System wide configuration file is "C:\Users\Admin\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
Using Port : COM6
avrdude: Send: 0 [30] [20]
avrdude: Recv: . [00]
be80be
Joined Jul 5, 2008
2,400
It should be this STK500.
stk500v1 the wrong progammer
There are 3
arduino as isp . Thats the one you want
Not the arduinoisp
Or arduinoisp.org
