a simple question about SCR
ericgibbs
Joined Jan 29, 2010
21,557
The simulation shows that point 'A' on your diagram shows a voltage high spike when the Vcc goes from 0V to the Vcc value.
As you can see from the plot, Vgate is partially high, before Vcc goes high, then it jumps to a higher voltage level as Vcc is applied.
Is that what you are asking.?
E
xljin2014
Joined Nov 11, 2014
120
E
why is like that?
ericgibbs
Joined Jan 29, 2010
21,557
I think BG is added from outside, not decide by vs.
Look at the sim circuit you will see that the Vgate is Enabled by the 6V driving current thru the R2 resistor, then thru the Gate tthen via the SCR internal resistance to 0v.
This gives a voltage at the Gate of approx 600mV. [It is Enabled]
When the Vcc is applied, the extra current thru the SCR raises the Gate voltage to approx 800mV
E
BobTPH
Joined Jun 5, 2013
11,636
Perhaps this answers your question. Staring Vcc at 0 and ramping it up, here is what happens to the voltage at A. As to whether there is a parasitic capacitance, yes, there is always a parasitic capacitance in every circuit element. Usually, it can be ignored.
Bob
xljin2014
Joined Nov 11, 2014
120
E
I think this involves inner structure of scr. still don't know how 600MV and 800MV come.
xljin2014
Joined Nov 11, 2014
120
Bob
yes, that's what I think. and now I'm wondering about va spike(fig eg984) it goes to 0v again, and scr still on , right?
