a simple question about SCR
xljin2014
Joined Nov 11, 2014
120
hi, friends,
the circuit above is a resistor connects with a scr(silicon - controlled rectifier). my question is:if point A is 0V in the beginning, and Vin is of high voltage, will voltage of A go up and SCR can start conducting? I mean if there's parasitic capacitor between SCR anode and cathode.
Ian0
Joined Aug 7, 2020
13,248
A can never be 0V (Unless Vcc=0V) Even if the SCR is on, “A” will never get lower than 0.8V.
Vin can never get higher than about 1V, because there is a diode between gate and cathode.
If A is at a low voltage, then the SCR is on, and it will remain like that until Vcc is switched off (more specifically, until the current through R falls below the holding current of the SCR) regardless of what happens at Vin.
If A is at Vcc, then the SCR is off, and it can be switched on by passing a current greater than the trigger current between Vin (gate) and cathode. The voltage at A will then fall to about 0.8V.
Ian0
Joined Aug 7, 2020
13,248
why? what if we let it be at the beginning?
If Vcc is present, then A will equal Vcc if the thyristor is OFF and A will equal 0.8V if the thyristor is ON.
(look up “on-state voltage” in the datasheet, you will generally find a figure of about 1.2V at full current, down to 0.8V at low current.CAAEFD71-349E-4431-B014-1F45CA516950.jpeg
BobTPH
Joined Jun 5, 2013
11,631
If nothing is connected to Vcc, the voltage at A is unknown, not zero. As soon as Vcc is connected, it is at Vcc.
Bob
xljin2014
Joined Nov 11, 2014
120
Bob
so when Vin about 1v is added, and Va is high, then current flows through r and scr, and A comes down to 0.8v . is it right?
second, if we connect A to zero at first, how will it goes to 0.8v after VCC is added?
BobTPH
Joined Jun 5, 2013
11,631
If you connect A to 0V, then the SCR is shorted out, not even in the circuit.
What are you getting at? I suspect you have in mind some exploitation of what you think is happening. Tell us what it is, and we can tell you whether or not it will work.
Bob
xljin2014
Joined Nov 11, 2014
120
Bob
I just want to know how point A goes to 0.8V if it is 0V originally , I suspect there are parasitic capacitors between anode and maybe gate or cathode and VA can go up as capacitors charge.
bertus
Joined Apr 5, 2008
22,995
Did you see this picture in the PDF I posted?
There will be no current through the load as long as the gate current is below IL .
Bertus
ericgibbs
Joined Jan 29, 2010
21,552
hi 2014,
This is what LTspice shows, remember this is in simulation.
1. The Gate is ON, with Vss Low
2, Gate still ON, Vss pulled High.
3. Vss switched off after a delay.
Expanded the Xaxis for the Vss going High
xljin2014
Joined Nov 11, 2014
120
hi 2014,
may I ask a question pls? in pic EG985, does it mean when vs added, it causes vg goes up, and va goes up from 0v?
