LED lamp simple circuit question
rolfknudsen
Joined Jan 27, 2025
Hello
New here and greatly appreciate any input on the following:
I have a table lamp design which has a 700 mA LED. This is driven by a 12v wall power supply and need an inline dimmer switch.
At the moment I can source a 350mA dimmer switch, but would like a 700mA.
Is there a small module I can house in the lamp after the dimmer switch, before the LED so I can have a 12V dimmer switch on the cable, going to this module that then puts out more or less current so the LED lamp is dimmed?
Diagram.jpgOr am I going about it in the wrong way?
Ideally I would only like max 12-24V from the wall power supply, so I do not have the risks of mains power design in the lamp itself. I am NOT an electronics engineer, but a designer.
Thank you!
28,420
You might be able to use a variable DC supply with a maximum out of 12 volts. If the light also has a battery power option it will be very simple to see if it gets dimmer with a weak battery. Some kinds will others will not. A variable linear regulated DC supply is very simple and easy, but not very efficient.
Worth experimenting a bit, though.
DC_Kid
Joined Feb 25, 2008
1,242
The LED's in the lamp are probably driven by an IC or two (maybe). If there's any kind of LED drive or controller in the lamp, then inlining a 12v dimmer may not work.
Find a 6vdc 5vdc wall wart and power the lamp from that, do you get 1/2 the light, does it work w/o flicker?
