Unfortunately it was a ground bar and they all shorted out. Budum-bum! I'm here all week folks.
Actually I've been looking for a solution for a few days and working on what most of you would consider fundamental. However, I am just a hobbyist and I need your opinion/help.
My issue is that I need to keep an SSR active after power is removed. I searched for 555 timer circuits but NPN transistor circuits keep popping up and after a closer look seem to make more sense. Below is a circuit drawing.
Power goes in and out of the SSR to an NPN. Then to a capacitor then on to the N-Channel mosfet. The source side is to ground. The mosfet gate is controlled on/off elsewhere. When it is off, I would like the SSR to be kept alive for about 5 seconds. IDK if the values of the resistor and capacitor are correct, they are just random values for now. I added the separate ground to the capacitor. My thinking is that if the only ground is through the mosfet and it gets shut off, then there is no other ground for the NPN circuit to work and the whole thing would just shut off.
What do you guys think? Will this work? For the life of me I cant get this to sim in LTSpice.
Thanks
Carlo
Thanks
Carlo
