9-0 down counter using JK Flipflop
Mondemundi
Joined Sep 20, 2016
4
Hi ! I am currently making a 9-0 counter using a jk flipflop and a 7 segment.
It starts to countdown but the problem is it starts at 15 not in 9 how can i make it start at 9 and reset again. Thank you very much !
AlbertHall
Joined Jun 4, 2014
12,629
connect the appropriate set/reset pins of the flip-flops to the active state (might be high or low depending on which JK you are using) to set the '1001' state.
dl324
Joined Mar 30, 2015
18,362
Welcome to AAC!
Is the counter synchronous or asynchronous?
Is this homework?
Post a schematic. Anytime you ask a circuit question and don't post a schematic, expect to be asked to do so.
Mondemundi
Joined Sep 20, 2016
4
Welcome to AAC!
Is this homework?
Yes sir this is an Asynchronous Counter..
I am currently working on this and getting really frustrated.. i have attached the schematic i made.. the other preset and clear are on the HIGH state
pls check if its right Thank you very much
dl324
Joined Mar 30, 2015
18,362
Is this homework?
Why are you decoding 10? This is a count down counter that starts at 15. You need to get the counter out of the illegal states when the count is 15.
