741 opamp data sheet help
Random3s
Joined Jul 30, 2014
38
I am writing a report concerning inv and non inv op amps. The inverting op amp circuit was 18v, + or - 9v and the amp was able to swing within a couple of volts to the supply rails, at around 7v max. I understand this is usual behaviour for 741 op amps, but would like to know what its referred as on the data sheet. Below is a link to the 741 model iam using, but I cant find anything in the sheet to confirm this behaviour. I am not sure it would be enough to state that "commonly 741 opamps are able to swing within a volt or 2 of the supply rails".
Thanks in advance.
LM741 data sheet
Random3s
Joined Jul 30, 2014
38
Thanks guys, so the voltage output swing is provided as a ratio of a given supply to a set RL value. In this case is RL the feedback resistor, from the output back to the inv input? (standard inv and non inv amp config)?
Could someone also point me in the right direction with regards to the bandwidth of a 741, there isnt a badwidth stated in the data sheet, but my project build had a break freq of 6kHz.
thanks again
shteii01
Joined Feb 19, 2010
4,644
Normally RL is LOAD RESISTOR, from output to ground.
Jony130
Joined Feb 17, 2009
5,601
Yes, without RL resistor, feedback resistor is a load for opamp
Well, the data sheet give as Gain bandwidth product = GBP and additional if we know the voltage gain we can find breakdown freq.
For example for non-inverting amplifier with gain equal to 10V/V we have
Fc = GBP/10 = 1MHz/10 = 100Khz but for inverting amplifier with a gain equal to -10V/V we have
Fc = GBP/( 1 + |10|) = 1MHz/11 = 90.9kHz .
And for voltage follower we have
Fc = 1MHz/1 = 1MHz but for inverting amplifier (gain -1V/V) we have Fc = 1MHz/ (1 + |1|) = 500KHz
Of-course this is true only if we have no capacitors across Rf resistor or parallel to the load resistor.
33,325
For the data sheet you linked in the OP, there is a line for Output Voltage Swing that lists the swing for various supply voltages and load conditions. It also supplies a bandwidth spec based on rise-time measurements (be sure you read the Notes in datasheets). This is most likely the gain-bandwidth product for an opamp.
