741 IC issue. Still a beginner.
Yuseph
Joined Jun 8, 2020
49
Yo guys i have a 741 ic issue.
R2 (at the bottom)= 10kohm
R1 = 1kohm
Differential V - / v+ = 8v
With respect to the gain formula the gain result should be 11.
On the Imput side i have 100mV so on the output i should normally get 1,1V. And im getting 0 instead so what the heck is that.
I changed the ic 3 times. So its not the ic. What am i doing wrong ?
Yuseph
Joined Jun 8, 2020
49
Dude. Negative is connected to pin2 and positive to pin3. Its a noninverting amp. Whats wrong with that.
Papabravo
Joined Feb 24, 2006
22,082
Dude -- those are the inputs. Pins 4 and 7 are the power pins. What is connected to the power pins?
Do you have a schematic drawing, that conveys your intentions? The picture is nearly worthless for that purpose. You need to understand these things when asking for help.
Yuseph
Joined Jun 8, 2020
49
You're right.
Pin4 v-
Pin7 v+
Pin2 imput -
Pin3 imput +
OBW0549
Joined Mar 2, 2015
3,566
Dude. You're doing it wrong. You DO NOT connect your input between pins 2 and 3.
The correct way to make a non-inverting amplifier with an op amp is shown right on page 1 of the 741 data sheet. Always read the data sheet.
dl324
Joined Mar 30, 2015
18,328
R1 = 1kohm
Yo dude. How about posting a schematic with the relevant details (like power supply voltages)?
I can't see where the hidden terminal of the 10k resistor is going. Looks like it might be pin 1, but that would be a mistake. The feedback resistor is 1k, so you're not going to get a gain of 11.
If you're going to post a 4MB picture, at least make sure it shows relevant details clearly. Then reduce image size for those who have slow internet connections.
What is the battery chemistry? If it's NiMh or NiCd, the circuit can't work because the common mode input range will be essentially nil.
LM741 was a good opamp in it's heyday (best thing since sliced bread at the time), and is still decent for those who know how to use it; but it's not suitable for newbies who can't, or won't, read the datasheet.
Yuseph
Joined Jun 8, 2020
49
I dont know about the chemistry.
R2 is 10kohm and r1 1kohm. That gives 11.
Maybe im not measuring properly. Im touching the black probe to imput 2 and the red probe to the output. So i dont know the book doesnt give those details
dl324
Joined Mar 30, 2015
18,328
What type of batteries are you using?
R1 is the feedback resistor. You'd get a gain of 1.1 if you wired it correctly, but R2 is shorted. It seems that you're trying to measure a DC voltage of two of your batteries in series and you're using 2 of those batteries in series as the power source. That don't work. You need to read the datasheet.
The picture you posted has a blue wire that wasn't present in the original picture.
Your circuit can't work. LM741 doesn't work well with a single supply or bipolar supplies of +/- 2.4V
EDIT: Your original picture shows the input being from a battery holder. That source doesn't have a common ground with the opamp power source. Also, as already mentioned, you don't put your input voltage across both inputs.
38,508
The basics:
The V+ and V- power are referenced to ground, not to each other so you need two voltage sources (batteries) with one terminal of each connected to ground.
And each need to be at least 5V for the 741 to operate at all.
Also the input and output can only go to withing about 2V of the supply voltages.
Audioguru again
Joined Oct 21, 2019
6,826
checked with the simulation software
The circuit above does work correctly. Changing the voltage Using +/- 8V supply and a gain of 10X or approx 1Vpp output.
R1 should be about 4k. measuring output using multimeter set at AC. The VRMS is then converted to V P-P should be .707
https://www.allaboutcircuits.com/tools/rms-voltage-calculator/
No. If R1 is 4k and R2 is 1k then the voltage gain is 5.0, not 10.
No again. If VRMS is 1.0V then V P-P is 2.828V. If Vpeak is 1.0V then VRMS is 0.707V.
Yuseph
Joined Jun 8, 2020
49
All circuits on the datasheet of a 52 years old 741 opamp have a supply voltage of 30V. Some of them work with only 10V.
Do it like this:
Lol i dont even have 6 x 1.5v batteries at my disposal right now. I guess ill postpone to tomorrow.
Thanks for that very clear schematic anyway. Its the fact that v+ and v- were two different supply sources that i missed. Its not drawn like that in my book. And the guys on youtube are long on theory. They skipped the demonstration.
Cant wait to try it.
anyway 3 power sources ?? Why would someone go into so much trouble to amplify voltage ? There must be simplest ways now
And im not sure how i could ever use that on a circuit. Since i tackled the microprocessor topic now.
34,814
Is your input signal always positive?
Then you only need a positive power source. You cannot use 741 op-amp for this. You need a rail-to-rail op-amp that can work on a single supply. Something like LTC6261 should work.
ci139
Joined Jul 11, 2016
1,989
i recently re-checked the formulas for (img. src. = https://www.maximintegrated.com/en/products/analog/amplifiers/MAX478.html - irrelevant)
so i got the calculations (at hand this time)
\[U_0=\left({U_X-U_1}\right)·\frac{R_0}{R_0+R_1}+U_1\\ {\ }\\
U_0=U_X·\frac{R_0}{R_0+R_1}-U_1\left({\frac{R_0}{R_0+R_1}-1}\right)\qquad {}^{(1}\\ {\ }\\
U_X=\left[{U_0+U_1\left({\frac{R_0}{R_0+R_1}-1}\right)}\right]·\frac{R_0+R_1}{R_0}\\ {\ }\\
U_X-U_0=U_0\frac{R_0+R_1}{R_0}-U_0+U_1\left({1-\frac{R_0+R_1}{R_0}}\right)\\ {\ }\\
U_X-U_0=U_1\left({1-\frac{R_0+R_1}{R_0}}\right)-U_0\left({1-\frac{R_0+R_1}{R_0}}\right)\\ {\ }\\
\frac{U_X-U_0}{U_1-U_0}=1-\frac{R_0+R_1}{R_0}=\frac{R_0-R_0-R_1}{R_0}=-\frac{R_1}{R_0}\qquad {}^{(2}\\ {\ }\\
\begin{align*}\qquad \qquad \qquad \qquad \qquad \qquad \qquad \qquad \qquad \qquad \qquad \qquad \\
\hline \end{align*}\\
\mathbf{U_1=0}\qquad U_0=U_X·\frac{R_0}{R_0+R_1}\ {}^{from\ the\ (1}\qquad \frac{U_X}{U_0}=\frac{R_0+R_1}{R_0}\\ {\ }\\
\cases{U_X-U_0=\left({-U_0}\right)\left({-\frac{R_1}{R_0}}\right)\ {}^{from\ the\ (2}\\ {\ }\\ U_X=U_0\left({\frac{R_1}{R_0}+1}\right)}\qquad \frac{U_X}{U_0}=\frac{R_0+R_1}{R_0}=1+\frac{R_1}{R_0}\]
ci139
Joined Jul 11, 2016
1,989
opa2.gif\[\frac{U_Y}{U_1}=\frac{R_0+R_1}{R_0}\qquad \frac{U_X-U_0}{U_Y-U_0}=-\frac{R_3}{R_2}\\ {\ }\\
\boxed{U_X=}\ U_0\left({\frac{R_2+R_3}{R_2}}\right)-\frac{R_3}{R_2}U_1\left({\frac{R_0+R_1}{R_0}}\right)\ {^?= {}_?}\ \mathbf{...}\ =\left({U_0-U_1}\right)\frac{R_2+R_3}{R_2}\ \boxed{=\Delta U_{IN}\left({1+\mathbf{M}}\right)}\\ {\ }\\
?\qquad \frac{R_2+R_3}{R_2}=\frac{R_3R_0+R_3R_1}{R_0R_0}\ {^?= {}_?}\ ...\ =\frac{R_3\frac{R_0}{R_1}+R_3}{\frac{R_0}{R_1}R_2}=\frac{R_3\frac{R_3}{R_2}+R_3}{\frac{R_3}{R_2}R_2}=\frac{R_2+R_3}{R_2}\\ {\ }\\
R_0=\frac{R_3\left({R_0+R_1}\right)}{R_3+R_2}\\ {\ }\\
\cases{\underline{R_0R_3}+R_0R_2=\underline{R_0R_3}+R_1R_3\\ {\ }\\
\boxed{R_0R_2=R_1R_3}}\qquad \frac{R_3}{R_2}=\frac{sR_0}{sR_1}=\mathbf{M}\qquad \mathbf{...} \uparrow
about ... High impedance test
High frequency test
Audioguru again
Joined Oct 21, 2019
6,826
ANY opamp can is a positive and negative supply, or use just a positive supply if its + input is biased at half the supply voltage and input, output and feedback to ground coupling capacitors are used like this:
