Hi all. I'm a complete newbie to all of this but willing to give it a shot. I have a project where Ive built a 1.2m lego display truck and trailer that holds the centre speaker for the home theatre in the entertainment unit. I have placed inside the sleeper a wireless door bell and it works great.
What I'm trying to do now is light it up by either a push of a button or from the doorbell ringing. the door bell has a green led that lights while it is activated so I'm thinking this as a trigger through a relay to power the lights. Also wanting to have a simple on/off switch. the led im using are 0603 for their size to fit inside a lego stud. Wire gauge is 27 for the mains and 32 to each led to fit between brick plates. I have 52 orange, 16 red and 7 white ones to light up but not to their full brightness. How would I go about this and what is the smallest power required to run them. Do I put them in a parallel or series circuit and do I wire each colour separately or can I put them all on the same power wire. Someone told me that I could run 32 in parallel with a 2.2ohm resistor with 2xAAA batteries?. I have room under the truck for up to 4 AAA or one 9v. Not sure how to start all of this.
Every bit of help is much needed.
Cheers Jono
Cheers Jono
