6V motor battery
dude1
Joined Jan 30, 2018
16
I have the 6V 100rpm motor visible on the picture.
It works with 6V from the transfo visible on right, but not from the AA battery pack.
Is it a problem of insufficient amps or something?
What kind of 6V battery could I use that would still be reasonably small and do the trick?
38,868
The two AA battery pack you show is only 3V and you need 6V.
Need to know how much current the motor takes before a battery can be recommended.
How long do you need the motor to run with the battery?
dude1
Joined Jan 30, 2018
16
There's actually 4 batteries, even if they don't appear on the pic.
Here are the details about the motor:
Voltage: DC 6V
No load
Speed 100rpm
Current (A) 0.01
Rated load
Speed 80rpm
Current (A) 0.03
Torque (KG.CM) 0.40
Stalling
Torque (KG.CM) 3.20
Current (A) 1.0
It will need to turn for a couple of seconds about 10 times during a meal, it's supposed to become a twirling Swiss fondue fork
ericgibbs
Joined Jan 29, 2010
21,601
Hi D,
Do you have a voltmeter that could check the motor voltages when the battery is connected.?
E
Does reversing the +/- connections to the motor give the same problem.?
smooth_jamie
Joined Jan 4, 2017
107
Just a shot in the dark but could the batteries be rechargable 1.2V, instead of 1.5V? If that's the case the battery pack voltage would only be 4.8V. Also, (daft question) How do we know the batteries aren't empty?
dude1
Joined Jan 30, 2018
16
Those are non rechargeable.
I checked with a voltmeter, there's indeed 6V for the battery pack
I tried to revert the wires, but to no avail.
I'll check the motor voltage when the battery is connected when I'm back home.
dude1
Joined Jan 30, 2018
16
I tried with a different set of AA batteries, which total 5.76V instead of 6.06V with the original ones and this time it worked.
Go figure!
Thanks for all your excellent hints.
AlbertHall
Joined Jun 4, 2014
12,653
Go figure!
What chemistry are the two sets of batteries - zinc-carbon, zinc-chloride, alkaline...?
dude1
Joined Jan 30, 2018
16
I already threw the bad ones away, because they also prevented a drone remote from working.
Quite phenomenal pieces of junk.
The ones that work are alkaline.
