Hello all,
I am glad I came across this site as I am a 37 year old learning how to soldering and work with electronics and have taught myself up to this point. I have no real support from anyone around me that can help me/mentor me so I have had to go to magazines, Youtube, and other sites to learn about soldering, electronics, power, etc. And, for the most part, I have done pretty good at figuring things out when they don't work. However, the latest issue I am stuck on and believe I may know the issue but I am not 100% so that is why I searched for a site like this.
I did a search here but, since I am definitely new to this field, I wasn't sure what to look for. I am starting off by building a racing drone and I have two PCB boards connected to each other via gnd/5v pins. One board connects to a LiPo battery and then provides the 5v power to the other board. The other board is where the issue is. It powers up correctly as I am able to power and run my four motors via a 6-pin, three row connectors but I have another row where I have soldered a 6-pin, single-row connector to the board. On this row, I am to connect a receiver to three pins, one gnd, one 5v, and one sbus.
When connected to the 5v/gnd pins...the receiver doesn't power. I have verified the receiver works as I have connected it to the 5v/gnd that powers the board and it works just fine. I have connected my multimeter to the two pins and see it register barely 1v (again...new so I could be reading this wrong). One thing I remember when I soldered this row is that I got the gnd pin too hot and somehow managed to push the pin to where it sits lower than the other pins (I.E. pushed it through the plastic casing and it hangs more through the bottom than the top). My solder joint looks good as it is the shape of a volcano on both the gnd and 5v.
What I am wondering is why I am not getting 5v out of these pins? Did I push the pin too far in and its not making a good connection with the cable (I believe its called a DuPont connector), could something be wrong with the board, could my soldering joints still not be that good?
Any help would be appreciated! Although I have this problem, I am loving working on electronics and wished I started at a younger age!
Troy
Troy
