555 w/ 4017 IC Troubleshooting Help
Alb3rtV3
Joined Oct 11, 2016
2
Hey Everyone,
I am a new member here but I am no stranger to forums. So, my issue and I cannot figure this out. I used a circuit I got online to create an LED Chaser circuit. Everything seemed fine until I fire up the circuit. The LEDs chase...but they skip one over. I have attached a video as well as the schematic I used. Please let me know what you all think, I cannot for the life of me figure this out.
18,129
Which one skips? The video does not show it.
And BTW, you only need one resistor since only one LED is on at any time. Actually you don't even need that one, since the 4017 cannot source enough current to damage your LED.
Alb3rtV3
Joined Oct 11, 2016
2
If you look closely, Output 1 and Output 3 seem to be skipped. Output 0 and 2 do engage. Its perplexing to say the least. But why only 1 resistor? Should each LED have one resistor per...
djsfantasi
Joined Apr 11, 2010
9,237
Obviously the schematic and the breadboarded circuit are not the same. So it's impossible to comment without an accurate schematic.
@wayneh explained why you need only one resistor. The circuit you show will only have one LED on at any given point in time. So you only need one resistor... One LED; one resistor!
eetech00
Joined Jun 8, 2013
4,713
Hi
1. The 4017 can only output 6ma max per output. Try changing the resistors to 1k ea.
2. I would recommend using 1 resistor per LED as you've done or use a resistor pack.
3. Connect a resistor and cap in series (10k resistor to gnd, 0.1u cap to +v) . Connect the junction to the reset pin of 4017
to ensure the count always starts with 0.
4. If you need more output current, you can use two ULN2004's connected to the outputs of the 4017.
k7elp60
Joined Nov 4, 2008
562
In simple terms you connect all the LED cathode's together and put resistor between that connection and ground. I would add a 10uF capacitor between Vcc and ground near the 555 also.
18,129
Guys, he has a skipping problem not a resistor problem. Don't make me regret mentioning the redundant resistors.
Oops, never mind. I see you both addressed the need for decoupling capacitors.
Dodgydave
Joined Jun 22, 2012
11,395
I only see 4 Red wire outputs, clearly your built circuit is not the same as the diagram.
You could have put the leds in reverse by mistake.
hp1729
Joined Nov 23, 2015
2,304
Hey Everyone,
The output of the 555 is going to be a really short low pulse. I suggest a resistor between the Discharge and Threshold/trigger inputs.
