Hello all,
Am new here and I was impressed the way people interact and help each other here.
I was making a project based on PIR motion sensor.
The circuit works as the motion sensor senses the motion, it gives output (3.3V) to the 555 timer (Pin 2) which i have used in Monostable mode.
Now the output of this 555 timer (Pin 3) is connected to the relay in such a way that as the o/p gets low, a lamp turn ON through relay.
This circuit works fine <ON BREADBOARD> and as i have expected
Now when i made this made the same circuit on a PCB it doesnt function as in breadboard. And frankly, i have checked it about 10 times and i found no mistake or shorting in the Souldering.
ISSUE is:
Whenever the Motion sensor triggers the timer (Pin 2), Pin 3 should go low. But it isnt going low. I need help.......
ISSUE is:
