555 fading LEDS
adamclark
Joined Oct 4, 2013
472
hello again,, Im working on a Christmas light project with my children. We are building the star for our tree with blue LEDs and I want to make them oscillate, flash and fade. Ive worked with the 555 timer a few times and I know I can make them either oscillate or flash all at once with them, but I want to be able to make them do all of them either on a cycle or be able to choose which one they do. I think a 555 can do this but I cant find a schematic for it anywhere. I appreciate any help you can offer.. thanks
Dodgydave
Joined Jun 22, 2012
11,395
You can put a capacitor in parallel with the led to slow the pulse down, like this circuit,
or use a counter chip to give a moving chase effect, again put caps across the leds with a series diode to block the discharge by the chip.
chaser circuit
adamclark
Joined Oct 4, 2013
472
thanks for the ideas,, will definitely check out the 4017.. what do you think would cause a shimmer effect,, kinda like real stars flicker some.. I just want it to do something other than just flash..
GopherT
Joined Nov 23, 2012
8,009
You could also use two 555 timers with slightly off frequencies (100 Hz and 101 Hz) then run both through and AND gate to get a beat-frequency oscillation and duty cycle would vary the apparent intensity. Temperature effects may cause the frequency to shift a little over time and, therefore, a lot of shift to the visible beat frequency. It could be fun though. You might need a pass transistor if you are driving more than one LED from the AND gate.
Bernard
Joined Aug 7, 2008
5,784
Or use a flickering candle LED to drive the blue LED's. For more of a shimmer than flicker, partially filter the candles PWM signal.
Do the LED shimmer together, or in smaller groups. How many LED's?
adamclark
Joined Oct 4, 2013
472
I have several different ways to fade LEDs with 555s in my article...
LEDs, 555s, Flashers, and Light Chasers
If you define what you would like a bit tighter I could probably help draw something specific.
Thank you Bill_Mardsen.. I was really just waiting for you to chime in.. I would like to use 555 timers as the only ic I use, I would like for the LEDs to flash, oscillate, fade, and flicker(but I think a high oscillation rate would cause that effect). And I would like to cycle through each effect with a single button or have them cycle through all of them automatically...
GopherT
Joined Nov 23, 2012
8,009
That is a tall order for a 555-only circuit.
adamclark
Joined Oct 4, 2013
472
I know,, Im open to other ic's as well. but im still learning so I wanted to keep it as simple as possible.. What I don't want due to time constraints and skill levels are the use of microcontrollers.. if I could achieve what I want from a small circuit with a few different ic's then its all good.. the main reason for the 555 only circuit is because ive used them before and am kinda familiar with them,, and the fact that I have over 20 of them just hanging out in my box...
Wendy
Joined Mar 24, 2008
23,820
Have you looked at From Four, Twenty? I was basically thinking Christmas Tree lights when I envisioned it.
It just occurred to me you could use the fader circuits along with this schematic. Not sure how it would look, but it could be interesting.
ScottWang
Joined Aug 23, 2012
7,505
Twinkle, twinkle, little star, How I wonder what you are.
Whatever you call it twinkle star, breathing LED, slow bright and dark LED, they are almost the same idea.
You can changing the frequency of NE555 to make the LED lighting time keeping longer, or adjust the values of R2,R3,C3 to changing the time of going bright and the time of going dark.
adamclark
Joined Oct 4, 2013
472
thanks, I will try to build the 555 only schematic first, my only question right now is how would any of these work with multiple LEDs? I plan on using 20 blue LEDs to decorate the star.
Wendy
Joined Mar 24, 2008
23,820
Here is the From Four, Twenty Schematic...
Eliminate D1 through D8 and the associated resistors, then replace them with this...
Use both schemes at the same time on pins 2,6 of the 555's, the PNP and NPN transistor configurations. You would have both twinkle and fade action at the same time.
adamclark
Joined Oct 4, 2013
472
That's really what I want.. so do I build the first one just like it is but without d1-d8 and add the lower 2 to it? and where do I add them? How many 555's would I need all together? I want to build this, but im having a little trouble understanding it and how would I connect 20 LED's to this?
Wendy
Joined Mar 24, 2008
23,820
The network of LEDs D9-D20 remains unchanged. Just modify each 555 to look like this...
Of course, the LED color is up to you. You can also use one fixed resistor instead of the variable. You can buy Darlington transistors prepackaged, no need to use 2 transistors unless they are in the junk box.
adamclark
Joined Oct 4, 2013
472
this is going to get built tomorrow after work,, stay tuned for assistance..lol... and this will do 20 leds without further modification? what does the variable resistor do, control speed?
