555 connections for monostable
denison
Joined Oct 13, 2018
334
Hi, I have a circuit for monostable operation of a 555 for a low going input pulse to a timed high output pulse.
Can anybody provide the circuit for the opposite. For a high going input pulse to a timed low output pulse. Only need very brief, in order of us, output pulse determined of course by the capacitor.
Papabravo
Joined Feb 24, 2006
22,113
Using an inverter is the easiest way to solve the problem. You can do this with a single transistor. How about a schematic of what you have.
Ian0
Joined Aug 7, 2020
13,296
F013581E-73AD-48A2-86F2-ADD25B9E4FCD.jpegSwap over pins 2 and 6. You then need a positive-going version of Discharge, which you can implement with a diode from the output.
THere will be a slight reduction in timing accuracy on low supply voltages because the capacitor is not fully discharged.
