Hi
I have to test an IC with 50 ohm logic at 20 MHz. The input signal is a 20 MHz square wave. The original test fixture has 26 AWG wire for transmission lines and does not distort the signals. I made a "paddle board" with 50 ohm transmission lines and connected to the test fixture through a cable with 50 ohm twisted pairs. The cable is 4 feet long. The signal is so distorted that the circuit is loaded down and the input signal resembles a sine wave at the paddle board. To add insult to injury the input signal is connected to 5 inputs of the test fixture by means of said 26 AWG wire.
I got a reasonable response by attaching a 50 ohm coax to one pin (disconnecting the others) and jumpering using 26 AWG to the other 5 pins. But the response loads the generator so I do not have amplitude control.
Any suggestions. I am going to respin the paddle board but do not know how to change it.
