5 led circuit with switch
Jason Barker
Joined Feb 7, 2019
Hi thanks for reading.
Im looking to make a circuit thats simply 5 LED's and an on/off switch powerd by a low voltage high capacity lipo idealy.
I'm not sure on how to set it out or what voltage/resistors i would need.
Thanks for your time!
danadak
Joined Mar 10, 2018
4,057
Then probably you will need a simple boost converter since a single LIPO
cell V may not be high enough to drive the 5 LEDs in series. Or are you
going to drive them paralleled ?
Regards, Dana.
Jason Barker
Joined Feb 7, 2019
Regards, Dana.
i would prefer parallel incase one of the LED's is damaged, i dont mind useing a stronger lipo, though i wouldnt want to go past 11.1V because size is an issue
iONic
Joined Nov 16, 2007
1,662
Your LED's specs are If(forward current) 20mA, and Vf(forward voltage) 3.0-3.3V. Being that they are purchased from ebay I generally down-rate the specs for safety/longevity. I will calculate based on a If=17mA and Vf=3.0V. I actually do this for all my circuits containing LED's.
With a single 3.7V Lipo, this is certainly doable.
Calculations: (LINK)
In parallel, each LED needs a limiting resistor as seen in the wiring diagram above. 47 Ohm(1/4W) is a standard resistor value and should be easy to find.
danadak
Joined Mar 10, 2018
4,057
As Ionic has show with LEDs in parallel you do not need a boost converter,
and your battery is fine.
Regards, Dana.
Jason Barker
Joined Feb 7, 2019
thats ace! thanks!
