Just gotta work on the fail safe now. Going to use a liquid sensor to detect when the water raises to a point where it is safe but I dont want more water. Using this, It will generate power to a relay and through that to a transistor killing power to the pump, I am aslo going to use a 555 ic to set a small delay between water detected and pump off. This is to stop the pump being switched off and on multiple times due to water ripples.
Already have the circuit in mind
