4060 chip for seconds and hours
Danielpalfrey
Joined Mar 29, 2016
84
Leds are now oscillating nicely. The LEDs I put in were new... But they blew... My guess is to much heat when I soldered them in. I am pretty novice at this stuff. I generally work with WIRES. I still have no Timer for the pump, I think the relay is caput which is thiesable since i took it off a previouse attempt that went really wrong
Danielpalfrey
Joined Mar 29, 2016
84
Ok, I rebuilt the circuit using all new parts and strip board. Got oscilation and leds flash, when i set up the recomended test though the leds connected to no and nc do not change? I have checked and checked and checked and can not for the life of me figure out whats going on...
Danielpalfrey
Joined Mar 29, 2016
84
I swapped out the 4060 for one (from the same supplier) that I havent yet used. This one kept the green LED on permanently... Faulty... I am not sure how to test the other one for faults, but it oscilates and when I probe the chip to check for voltage at pin 5 (using this for testing) I get no voltage at all. I held it there for 3 mins in total and never got a thing, so I am going to go to halfords and get a new one from them just to be sure
Dodgydave
Joined Jun 22, 2012
11,395
Set the timer to the quickest delay, and monitor that output with your meter or led, if the output goes high then its working, and the problem is driving the relay, if you look at the circuit the diode from the output stops the clock oscillator, and the transistor discharges the reset capacitor to start the timer again.
Get the oscillator to work, then test the fist output, then connect the relay.
Danielpalfrey
Joined Mar 29, 2016
84
Timer oscillates perfectly. Pin 7 goes live after 30 seconds. Pin 5 which should go high after 60 seconds never goes high. I have tested this with volt meter at the 4060
Dodgydave
Joined Jun 22, 2012
11,395
Ok, pin 7 goes high after 30 seconds, then it should be low after another 30 seconds and pin 5 will be high, then the next output and so on....
Danielpalfrey
Joined Mar 29, 2016
84
Pins 14 15 and 16 oscillate. Pin 5 doesn't go high nor does 6. Couldn't answer about the others at this moment as they are u tested
Danielpalfrey
Joined Mar 29, 2016
84
Just had a chance for a few more tests and found that when the yellow LED turns off the second time I get a vary slight voltage spike at the reset pin? what could cause this?
eetech00
Joined Jun 8, 2013
4,753
If you what Q4 to turn on every 30 seconds then it should be on for 15sec and off for 15sec.
Those values on that schematic don't look right.
What value did you use for C3?
For Q4 to turn on every 30 seconds:
If C3 is 10uF, then R3+R4 should be 85.2k. R5 should be 10x(R3+R4)=850k (nearest value is 820k)
Danielpalfrey
Joined Mar 29, 2016
84
ok, so after doing more checks, The pins go live, my 12V adapter was churning out 16v.... stupid thing, so now I am running off of a 9v battery. I was playing with it some more today and have found that all the pins do go live all accept for the pin that I am using to trigger the solenoid... so very annoying.
Danielpalfrey
Joined Mar 29, 2016
84
Ok, I now have this circuit working. I cleaned the board up for the third time to be safe and it still wasnt working, so I probed away with the multi meter and found (Due to an early mistake) that I had blown the transistor, I have now swapped this out and it works perfectly. Dialing in the 6 seconds was a little tuff because I unwitingly bought preset resistor that was none linear. Voltage raises fast at begining and hits near max about half way round. but I got it there. Just letting it run for a bit letting it click the relay make sure I am happy, then I can rig up the pump
