Yup! You're right. Sorry.Edit: You fellas are jumping the gun. TS needs to learn how to put digits out to the display first.
It's only 2.7 hours.Every second????? Do you realize that 9999 seconds is 6 days 56 mins and 37 seconds.That's a long time to wait to see if it is working. How about every 10 to 20 ms? Even 1000 seconds to see whether each digit rolls over to the next is almost 17 hours. 100 ms would be more practical for that purpose.
Here is my program that display 1234Suppose that you have a 4-digit number 1234.
Can you display "1" on the first 7-segment LED display (the one on the left)?
#define _XTAL_FREQ 8000000
#include <xc.h>
// PIC18F45K80 Configuration Bit Settings
// 'C' source line config statements
// CONFIG1L
#pragma config RETEN = OFF // VREG Sleep Enable bit (Ultra low-power regulator is Disabled (Controlled by REGSLP bit))
#pragma config INTOSCSEL = HIGH // LF-INTOSC Low-power Enable bit (LF-INTOSC in High-power mode during Sleep)
#pragma config SOSCSEL = HIGH // SOSC Power Selection and mode Configuration bits (High Power SOSC circuit selected)
#pragma config XINST = OFF // Extended Instruction Set (Enabled)
// CONFIG1H
#pragma config FOSC = INTIO2 // Oscillator (Internal RC oscillator)
#pragma config PLLCFG = OFF // PLL x4 Enable bit (Disabled)
#pragma config FCMEN = OFF // Fail-Safe Clock Monitor (Disabled)
#pragma config IESO = OFF // Internal External Oscillator Switch Over Mode (Disabled)
// CONFIG2L
#pragma config PWRTEN = OFF // Power Up Timer (Disabled)
#pragma config BOREN = SBORDIS // Brown Out Detect (Enabled in hardware, SBOREN disabled)
#pragma config BORV = 3 // Brown-out Reset Voltage bits (1.8V)
#pragma config BORPWR = ZPBORMV // BORMV Power level (ZPBORMV instead of BORMV is selected)
// CONFIG2H
#pragma config WDTEN = OFF // Watchdog Timer (WDT disabled in hardware; SWDTEN bit disabled)
#pragma config WDTPS = 1048576 // Watchdog Postscaler (1:1048576)
// CONFIG3H
#pragma config CANMX = PORTB // ECAN Mux bit (ECAN TX and RX pins are located on RB2 and RB3, respectively)
#pragma config MSSPMSK = MSK7 // MSSP address masking (7 Bit address masking mode)
#pragma config MCLRE = ON // Master Clear Enable (MCLR Enabled, RE3 Disabled)
// CONFIG4L
#pragma config STVREN = ON // Stack Overflow Reset (Enabled)
#pragma config BBSIZ = BB2K // Boot Block Size (2K word Boot Block size)
// CONFIG5L
#pragma config CP0 = OFF // Code Protect 00800-01FFF (Disabled)
#pragma config CP1 = OFF // Code Protect 02000-03FFF (Disabled)
#pragma config CP2 = OFF // Code Protect 04000-05FFF (Disabled)
#pragma config CP3 = OFF // Code Protect 06000-07FFF (Disabled)
// CONFIG5H
#pragma config CPB = OFF // Code Protect Boot (Disabled)
#pragma config CPD = OFF // Data EE Read Protect (Disabled)
// CONFIG6L
#pragma config WRT0 = OFF // Table Write Protect 00800-01FFF (Disabled)
#pragma config WRT1 = OFF // Table Write Protect 02000-03FFF (Disabled)
#pragma config WRT2 = OFF // Table Write Protect 04000-05FFF (Disabled)
#pragma config WRT3 = OFF // Table Write Protect 06000-07FFF (Disabled)
// CONFIG6H
#pragma config WRTC = OFF // Config. Write Protect (Disabled)
#pragma config WRTB = OFF // Table Write Protect Boot (Disabled)
#pragma config WRTD = OFF // Data EE Write Protect (Disabled)
// CONFIG7L
#pragma config EBTR0 = OFF // Table Read Protect 00800-01FFF (Disabled)
#pragma config EBTR1 = OFF // Table Read Protect 02000-03FFF (Disabled)
#pragma config EBTR2 = OFF // Table Read Protect 04000-05FFF (Disabled)
#pragma config EBTR3 = OFF // Table Read Protect 06000-07FFF (Disabled)
// CONFIG7H
#pragma config EBTRB = OFF // Table Read Protect Boot (Disabled)
#define S1 LATBbits.LATB0
#define S2 LATBbits.LATB1
#define S3 LATBbits.LATB2
#define S4 LATBbits.LATB3
void Port_pins_Initialized (void); //prototype function
unsigned char Display (unsigned char digit)
unsigned char pattern;
unsigned char SEGMENT[9] = {0x3F,0x06,0x5B,0x4F,0x66,0x6D,0x7D,0x07,0x7F,0x6F};
pattern = SEGMENT[digit] ; //The pattern to return
return (pattern);
void main(void) // main program start
unsigned char Digit1, Digit2, Digit3, Digit4;
int count=1234;
unsigned char temp1, temp2, temp3;
Port_pins_Initialized (); //// Initialize the device
while (1)
Digit1 = count / 1000;
temp1 = count % 1000;
LATD = Display(Digit1); //Display the Digit 1
S1 = 1;
__delay_ms(10); //10ms delay
S1 = 0;
Digit2 = temp1 / 100;
temp2 = temp1 % 100;
LATD = Display(Digit2); //Display digit 2
S2 = 1;
S2 = 0;
Digit3 = temp2 / 10;
LATD = Display(Digit3); //Display digit 3
S3 = 1;
__delay_ms(10); //a 10 ms delay
S3 = 0;
Digit4 = temp2 % 10;
LATD = Display(Digit4); //Display digit 4
S4 = 1; /
S4 = 0;
LATA = LATB = LATC = LATD = LATE = 0; // set all to 0
TRISA = 0b0000000;// all are output, Unused
TRISB = 0b0000000;// control signal S1, S2, S3, S4 (0-3))
TRISC = 0b0000000;// All are output, Unused
TRISD = 0b0000000;// segment board connected
TRISE = 0b0000000;// All are output, Unused
ANCON0 = 0; // digital port
ANCON1 = 0; // digital port
CM1CON = 0; // Comparator off
CM2CON = 0; // Comparator off
ADCON0 = 0; // A/D conversion Disabled
Before you do that, fix the compiler warnings:Edit I will try to write further code for up counter
If I may offer a critique of your code..Djsarakar.c:65:79: warning: excess elements in array initializer
Djsarakar.c:81:23: warning: implicit conversion changes signedness: 'int' to 'unsigned char' [-Wsign-conversion]
Djsarakar.c:82:22: warning: implicit conversion loses integer precision: 'int' to 'unsigned char' [-Wconversion]
3 warnings generated.
| Thread starter | Similar threads | Forum | Replies | Date |
| N | 3 Digit Frequency Counter | Digital Design | 93 | |
| 4 | 2-digit CD4026 counter not working | Digital Design | 8 | |
2-digit up-down counter (0000 to 1010) in logisim | Homework Help | 7 | |
| M | A 6 Digit Frequency Counter | Digital Design | 99 | |
| M | 3-Digit Counter | Digital Design | 46 |
