2-digit CD4026 counter not working
488 studios
Joined Nov 10, 2023
30
Hey, I built a 2 digit counter with cd4026's. On the first digit (one's place), the E, F, and G segments only light up on 6 and 8, and on the ten's place digit, the D, E, and G segments are permanently lit. My multimeter shows a short between those segments and the power rail, but the solder joints look fine. Can anyone help me fix this?
sarahMCML
Joined May 11, 2019
703
Three things come to mind.
You have no current limiting resistors in line with the LED's.
The LED's need to be very High Efficiency, Low current ones.
The CD4026's are not designed to drive displays directly.
ericgibbs
Joined Jan 29, 2010
21,595
hi 88,
The PCB track cuts are not clean, suspect copper links, check and clean up, the cuts and ensure that the adjacent tracks are not linked with unintentional solder bridges.
Give them a good clean and check.
Use a magnifying eyeglass
E
Added a few pointers.
Also note what Sarah posted
28,424
I see quite a few solder bridges, and that means that the soldering tip is too big. Also, too much solder has been used. I thik there were at least a total of six solder bridges, two in the very first row.
sarahMCML
Joined May 11, 2019
703
I also see many solder bridges and track shorts through partially cut track slivers shorting to the next track over. I always run a thin steel rule along every track after finishing a board to both remove the flux and detect shorts!
