I need help in relation to hooking up 3 x 1000kv high voltage converters in parallel. The idea is to make an EMP disruptor / jammer.
The issue I have is when I turn on the switch, I get the familiar noise that electricity is flowing but no sparks.
Powering the setup is 2 x 3.7v lithium batteries with 800mAh. Because they are also hooked up in parallel, total voltage remains at 3.7v and total current equals 1.6A. The wire I'm using is 8 gauge AWG wire (3mm in diameter).
Below is a schematic and photo for your perusal.
A bit of info with regard to each high voltage converter:
Voltage input = 3.7 - 7.4v
Current input = 0.5 - 1.0 A
Voltage output = 800 - 1000kv
Current output = 0.5 - 1.0 A.
Thanks in advance.
Thanks in advance.
