3 x High Voltage Converters in parallel - troubleshooting.
Status
Not open for further replies.
Anonymous User 30
Joined Sep 4, 2017
40
I need help in relation to hooking up 3 x 1000kv high voltage converters in parallel. The idea is to make an EMP disruptor / jammer.
The issue I have is when I turn on the switch, I get the familiar noise that electricity is flowing but no sparks.
Powering the setup is 2 x 3.7v lithium batteries with 800mAh. Because they are also hooked up in parallel, total voltage remains at 3.7v and total current equals 1.6A. The wire I'm using is 8 gauge AWG wire (3mm in diameter).
Below is a schematic and photo for your perusal.
A bit of info with regard to each high voltage converter:
Voltage input = 3.7 - 7.4v
Current input = 0.5 - 1.0 A
Voltage output = 800 - 1000kv
Current output = 0.5 - 1.0 A.
Thanks in advance.
Anonymous User 30
Joined Sep 4, 2017
40
Hi Papabravo,
The dimensions are about half an inch, a little over 1cm. I have been experimenting with different spark gaps to no avail.
The manufacturer says that each high voltage converter can produce 800 - 1000kv output, so I should have 3000kv output?
Thanks for your response.
Papabravo
Joined Feb 24, 2006
22,084
Hi Papabravo,
Whoa there cowboy. You connected them in parallel. Voltage sources connected in parallel don't add together. I think what you are doing is extraordinarily dangerous for somebody lacking a grasp of fundamental principles.
Anonymous User 30
Joined Sep 4, 2017
40
Hi Papabravo,
I understand what your saying now.
I understand the power supply side of things are correct but I cannot connect the output side of things in series its impossible the way those units are constructed.
Makes sense now, thanks for your help.
Status
