3-input/7-output decoder for a 7 segment display
Raphaello
Joined Aug 23, 2015
5
Does anyone know how to build a 3-input/7-output decoder? all segments are also in active high. I have been having some serious trouble with this concept, any help would be greatly appreciated.
JohnInTX
Joined Jun 26, 2012
4,787
Assuming you are looking for a display decoder:
How about a SN7447/8? Study the gate diagram in the datasheet to resolve your questions about the concepts involved.
MC4513B does it in CMOS with active high outputs.
For a 1 of 8 decoder, look at the 74138 and its variants.
GopherT
Joined Nov 23, 2012
8,009
Are you talking about 7-segment display (digits 0-9)? If so, then you will need more than 3 inputs to get all 10 possible digits.
Raphaello
Joined Aug 23, 2015
5
I have to design a 3 input (g0,g1,g2) decoder with a 7 line output (a to g) to link into a 7 segment display. all the segments of the display are activated on active high. and I have to assume that when 6 and 9 are displayed, the system only displays 5 segments not six. (so segment a in 6 is not active and segment d in 9 is not active)
g2 g1 g0 | a b c d e f g | display
0 0 1 | ? ? ? ? ? ? ? | 1
0 0 0 | ? ? ? ? ? ? ? | 7
0 1 0 | ? ? ? ? ? ? ? | 2
0 1 1 | ? ? ? ? ? ? ? | 4
1 0 0 | ? ? ? ? ? ? ? | 5
1 0 1 | ? ? ? ? ? ? ? | 0
1 1 0 | ? ? ? ? ? ? ? | 3
1 1 1 | ? ? ? ? ? ? ? | 6
I just cant figure out how to construct the logic or manipulate the logic of a 4 to 8 decoder. Ive tried to manipulate a 3 to 8 decoder's logic gates but Im trumped
ScottWang
Joined Aug 23, 2012
7,503
You said that you want to design a 4 to 8 decoder, but you just showing a 3 to 8 truth table, how is a another input, does that is enable pin?
Raphaello
Joined Aug 23, 2015
5
I want to build a THREE input to SEVEN output decoder... the truth table above has 7 possible outputs a, b, c, d, e, f, g. The truth table has 3 inputs G0 G1 and G2 (1, 2 an 4 respectively) Is that even possible?
ScottWang
Joined Aug 23, 2012
7,503
Your input G0,G1,G2 and the display number didn't like the normal number as :
000 - 0,
001 - 1,
010 - 2
011 - 3
100 - 4
010 - 5
110 - 6
111 - 7
The number what you post is specific of your home work or you setup?
absf
Joined Dec 29, 2010
1,968
Here is the truth table for your customized 7-segment decoder.
Now, are you able to design your decoder circuit using discrete logic TTL/CMOS gates?
Allen
32,965
The first step is to go through row by row and determine whether each question mark needs to be a 0 or a 1. If the segment is supposed to be lit, then it is a 1 since the display segment is active high.
You talk about when 6 and 9 are displayed, but 9 is not one of the values you can display.
absf
Joined Dec 29, 2010
1,968
I though that may be if doing the truth table would get him start thinking why are the "1" and "0" are there. If he didn't understand he would start asking questions and me or someone else would slowly guide him. But after seeing post #9, that should give him the "ah ha" moment.
Allen
ScottWang
Joined Aug 23, 2012
7,503
Allen
When you did that, it seems as you already did for him half of his work, since this is a home work, so we can't do too much things for the student, only guiding him.
32,965
Think about your circuit. Each of your 7-seg inputs will be HI for exactly one combination of your G inputs and LO for all other combinations.
Is that what you want?
Raphaello
Joined Aug 23, 2015
5
I assume so, as I am told "the segments of the display a, b, c, d, e, f and g are activated on active -high of the corresponding a, b, c, d, e, f and g input connections" and i can only display one numereric output as i only have one display to work with
32,965
But the whole idea is that as you change the values of the G inputs that the digit that is displayed changes.
You can apply eight different patterns to the G inputs, meaning that you can display eight different digits depending on which pattern is currently being applied.
Once you have the (correct) truth table, focus on each segment as a separate problem.
