3.7 volt led flashlight wiring
Parcgreene
Joined Sep 17, 2016
2
So i have a 7 bulb led flashlight that runs on 3 -3.7 volt 26650 batteries. I attempted to remove the head of the flashlight and wire it through a pvc tube to place the battery tube (powersource) further away. About 3.5 ft away from the flashlight head. I used thick 12 guage wire and it appears i fried the circuit board. Any ideas on what i did wrong and how to correctly determine the proper wire size needed?
ci139
Joined Jul 11, 2016
1,995
there are many things to pay attention in this movie
  • good scene lighting
  • good scene selection camera work
  • good picture quality
  • . . . ok
  • he uses quite a thick wire (drains off a lot heat from iron) still he manages a quick preparation of wire ends -- likely due right solder and paste and heat applied (notice the guy pre heats stuff to get them best temperature for following operations)
  • he cleans off old solder and prepares contacts before making a permanent connections
  • he does not keep contacts heated up for long periods (also solders by heating diode side ((with higher temperature tolerance)) not electrolythic cap side ((with lower one)) )
dl324
Joined Mar 30, 2015
18,341
Obviously you wired something wrong. Without pictures of your handy work, how can we tell you more??
Determine the maximum current required and consult a wire gauge table that includes current carrying capacity. Power transmission rating would be ultra conservative; you can use the chassis wiring ratings.
