2nd order filter output amplitudes
matt20
Joined Dec 3, 2020
Afternoon,
If I have a 2volt input for the below circuit (LM741 opamp), the gain would be 1+586/1000 = 1.586 giving me an output of 3.172 volts
So 20 log (vout/vin) = log(1.586) = 0.2
Therefore 20*0.2 = 4db on the pass band as per the AC analysis.
So for the corner frequency I calculated as
3.172*0.707 = 2.24volts
Therefore 2.24/2 =1.121302 = log(1.121302) = 0.0492
Therefore 20*0.0492 = 1db as per the AC analysis.
But on the transient analysis the output is 2.14v not 2.24v at 1Khz, what causes this voltage drop ?
The same is for at 3Khz, the attenuation is -15.152db on the AC analysis
But when I calculate results from transient analysis I get,
20log (326mv/2) so (326mv/2) = 0.163, therefore log (0.163) = -0.7878
Therefore 20*-0.7878 = -15.75db.
thanks matt.
Papabravo
Joined Feb 24, 2006
22,111
Two things:
  1. What is the actual magnitude of the errors?
  2. What is the value of VC and VE?
It is well known that the 741 is a very poor performer at lower power supply voltages. The output cannot even begin to approach the supply rails. IMHO, for the signal levels you are using ±10VDC supplies would be the minimum.
Ian0
Joined Aug 7, 2020
13,279
159Ω would be difficult for a 741 to drive. Try it again with 10nF and 15.9k, and see if that makes a difference. (And check the supply rails).
And if it’s just a SPICE simulation, you can afford a better op-amp!
matt20
Joined Dec 3, 2020
Hi thank you for your replies. So Im using microcap software for my simulation. At fc which is around 1k, theres a 0.1v (2.14 to 2.24) difference from my calculated to the actual on the simulation results.
And at 3KHz the transient simulation shows the output amplitude at 326mV, but to give me the -15.2db as per the AC analysis it should be around 347mV (20log(0.34731/2)=~15.2db.
What is the reason for these differences? Is it due to losses within the opamp its self.
Hope that all makes sense, sorry I'm still learning.
