2N5457 spice model
cktboy
Joined Apr 24, 2020
45
Does anybody have a spice model for 2N5457 JFET? I have been searching online, found some but they are not accurate which I tested in Proteus.
ericgibbs
Joined Jan 29, 2010
21,415
hi ckt,
Is this the Model you have tried.?
What errors did you find.?
E
.MODEL J2N5457 NJF(Beta=1.125m Betatce=-500m Rd=1 Rs=1 Lambda=2.3m Vto=-1.372 Vtotc=-2.5m Is=181.3f Isr=1.747p N=1 Nr=2 Xti=3 Alpha=2.543u Vk=152.2 Cgd=4p M=311.4m Pb=500m Fc=500m Cgs=4.627p Kf=1.045e-002f Af=1)
eetech00
Joined Jun 8, 2013
4,704
If you are claiming a model is inaccurate, you should present some evidence of the inaccuracy(s) so the developer can correct it.
cktboy
Joined Apr 24, 2020
45
@ericgibbs, this is the same model as provided by @Bordodynov. The drain curve in proteus for this model is shown below.
This model shows that, for Vgs=0V the Idd is 400uA and Vp=1.9V but the minimum value of Idds is 1mA(datasheet: https://global.oup.com/us/companion...icrocircuits/students/mos/2n5457-motorola.pdf).
while I understand that the spice model may not always be accurate and that there is wide spread of electrical characteristics in the same transistors due to manufacturing process, I still think that the model is not within acceptable level. but this is my view, the model could be correct so I was looking for more spice model to experiment.
cktboy
Joined Apr 24, 2020
45
previously i searched and found model in following links:
https://www.diyaudio.com/community/threads/pspice-for-2n5457.230743/
https://groups.google.com/g/sci.electronics.basics/c/TuYZGN3Tb2g?pli=1
BobTPH
Joined Jun 5, 2013
11,482
That spec is with Vds = 15V. Did your simulation have that?
Bob
eetech00
Joined Jun 8, 2013
4,704
Try this one.
.MODEL J2N5457 NJF(Beta=0.150m Betatce=-500m Rd=1 Rs=1
+ Lambda=2.3m Vto=-2.572 Vtotc=-2.5m Is=181.3f Isr=1.747p
+ N=1 Nr=2 Xti=3 Alpha=2.543u Vk=152.2 Cgd=4p M=311.4m
+ Pb=500m Fc=500m Cgs=4.627p Kf=1.045e-002f Af=1)
cktboy
Joined Apr 24, 2020
45
hmm if the spice model is good then it looks like there is something wrong with my drain plot in proteus but cannot find the reason. I have set the following in properties for dc transfer characteristics curve.
and the probes on the circuit for drawing drain curve is,
So what am I doing wrong?
eetech00
Joined Jun 8, 2013
4,704
Which model statement did you use?
The VGS stepping should be from 0v -1v
cktboy
Joined Apr 24, 2020
45
it is the same even with VGS stepping from 0V to -1V as shown below.
the curve is not visible as it is in order of micro amperes as shown in the previous graph
and here is how to draw drain curve in proteus:
what could be the problem? any suggestions?
ericgibbs
Joined Jan 29, 2010
21,415
hi ckt,
I have one query ref your image, are you sure of the vertical scaling, it uses 'm' which indicates milliamps .
If that is correct, the first plot shows 0 to 11mA scaling,? Post #11
So the plots are around 0.5mA
E
ericgibbs
Joined Jan 29, 2010
21,415
hi ckt,
This is a composite of your post '11 , enlarged and my LTS using 0 to -10Vgs and aY scale of 11mA.
Close match.
E
I would say you have a scaling problem and a slightly different FET model.
cktboy
Joined Apr 24, 2020
45
- I used the same model posted by @eetech00 in post #10:
The drain curve I got in proteus is: for Vgs from 0V to -1V, Vds from 0 to 25V and Id is 0.4mA for Vgs=0.
- which is same as @ericgibbs post 13
- while @ericgibbs on post #14 shows
which matches with @eetech00 graph in post #10 which shows 1mA at the top(but don't know what is Vgs for this curve).
But @ericgibbs circuit shows positive supply to the gate, I don't know whether it is due to this reason the drain curve is showing 1mA instead of 0.4uA for Vgs=0 and maybe @eetech00 is also using positive gate bias.
Because when I use positive gate bias I also get the similar curve as shown below,
But a JFET(n-channel) on a drain curve has max current Idss when Vgs=0V and negative bias Vgs is only applicable.
So what is going on here? is proteus wrong or model wrong or have i mistake somehere?
ericgibbs
Joined Jan 29, 2010
21,415
hi ckt.
I don't follow ref
But ericgibbs circuit shows positive supply to the gate,
Vgs is stepped from 0v down to -1v. no positive.?
E
eetech00
Joined Jun 8, 2013
4,704
Are you sure you've mapped the .subckt pins to the symbol correctly in the proteus library? Probably should recheck.
I am using 0v to -1v stepping on gate as is shown on the datasheet. You should be also.
In the graphic below, the top trace in each pane is the waveform at 0v vgs. The bottom trace is the waveform at -1v vgs.
You can see Id is at max (about 1ma) when vgs=0.
