2CL71A Adding in LTspice Library Error - Help Needed
mishra87
Joined Jan 17, 2016
1,063
Hi Guys,
I am trying to add 2CL71A in my LTspice library but i could not.
Below error :
File is attached herewith. Have a look of path where i place those two files.
eetech00
Joined Jun 8, 2013
4,721
Hey...sorry I did not understand?
Could you pleas elaborate more what should it be ?
The filename of the spice model file is "2cl71a_spice.lib"
But the .inc statement on your schematic is: .inc 2cl71A <----this is wrong.
The statement should be: .inc 2cl71a_spice.lib
mishra87
Joined Jan 17, 2016
1,063
NOT SURE IF YOU TRIED ABOVE.
STILL THE SAME ERROR
THANKS,
eetech00
Joined Jun 8, 2013
4,721
Yes. That won't work because you've specified ".\2cl71a_spice.lib" for the modelfile attribute in the .asy file. You've specified a path relative to the current folder (the schematic folder). You've also have the model file in the wrong folder.
It worked for me by placing the modelfile in the schematic folder.
If you don't want to use a directive on the schematic:
1. remove the path from the "modelfile:" attribute value
2. place the model file in the LTspice sub folder.
