24VAC to DC modules
35,245
The valve was already in an irrigation timer that had a programmed watering schedule.
I programmed my own microcontroller to include some additional intelligence with regards to rainfall and soil moisture.
Is your application for drip irrigation or water sprinkler? Not that it matters but sometimes the hose water pressure can make a difference.
28,450
I just arrived and read this thread.
NOW it seems that there is new information.
The TS owes the participants so far a lot more information as to the requirements and the resources.
DJ_AA
Joined Aug 6, 2021
502
So if we need to make 240V to 24V, what must we connect to the particular transformer?
I think I need to set it to Series mode.
DJ_AA
Joined Aug 6, 2021
502
This is what i have done on my PCB. Should i remove the shorts or would it still be ok? It seems like there are bing shorted in the transformer
DJ_AA
Joined Aug 6, 2021
502
Great, but are they already connected internally as well or is it a externally connection that normally needs to be done?
bertus
Joined Apr 5, 2008
23,013
They are not connected internaly.
If there was a connection, the series/parallel connections would not be possible.
Bertus
I would not make the PCB symmetrical like that, too easy to flip it and connect it backwards. No need for all the vias and fat traces- on the primary-side even 1A is seen (clearing the fuse, so the PCB traces are not the fuse).
The fuse rating should be on the silkscreen and in North America 300% fusing is OK for small transformers.
That gives for 240VAC 0.15A max. and around 83-100mA (for 120VAC 0.3A max. and around 0.167-0.2A) for the ball park fuse size.
Also note small VA power transformers have quite poor regulation, their output voltage goes high at light loads.
I see about 35% (Tamura 3FL24) giving close around 32VAC out at no load, for 44VDC at the bridge rectifier.
Your buck-converter needs to be able to take this.
DJ_AA
Joined Aug 6, 2021
502
The PCB has been sent for manufacturing as part of a prototype batch, so I can make changes in the next PCB run.
Originally, I was aiming to have a single transformer that would also contribute to the DC voltage, but I now plan to keep both transformers independent.
I have added a fuse on the 24 VAC side.
