24VAC to DC modules
DJ_AA
Joined Aug 6, 2021
502
Hi All
I have a 240V to 24VAC transformer to generate the voltage for some AC solenoids. Is it possible to use the 24VAC, through a suitable AC to DC module, to generate a DC voltage for the rest of the electronics? Ideally, the DC voltage would then be stepped down via a DC-DC converter.
sghioto
Joined Dec 31, 2017
8,745
Hi All
What DC voltage and current level is required for the rest of the electronics?
Here's a complete Module that can do that. Five models available with 5, 12 , 15, 24 and 54 volt outputs at varying current limits.
DJ_AA
Joined Aug 6, 2021
502
Excellent, I can use the one that outputs 15V.
I wonder if they do a 240 to 24VAC transformer as well. I will check their website out.
DJ_AA
Joined Aug 6, 2021
502
Yes, this custom design needs 24VAC
So I planning
240VAC -->24VAC-->15VDC
The 24VAC transformer needs to be adequate for both my relays and the transformer.
Or is it better to do the following on the PCB
240VAC -->24VAC
----------> 15VDC
I am thinking that with option 2, the 24VDC would not need to be as powerful?
35,071
Solenoids will pull down the supply voltage. They also generate a lot of noise spikes when switched on and off.
That is why I suggest using two separate supplies.
DJ_AA
Joined Aug 6, 2021
502
Ok , I aim to make small 2 L PCB with the both 24VAC transformer and 15VDC working independently but both connected to 240V. Is this a good approach?
35,071
For AC to DC conversion, do the math first. Full-wave bridge or half-wave centre tap will give different voltages.
24VAC will give about 26V x 1.4 = 36 VDC which is too high for 15 VDC output.
Calculate the power dissipation of the 3-terminal linear voltage regulator. Your aim is for an overhead voltage that is just right.
Another solution is to use a buck or boost SMPS (switch mode power supply).
sghioto
Joined Dec 31, 2017
8,745
I have seen some systems, for example, irrigation units, where entire systems work of the same 24VAC power supply. How would they achieve it all with 24VAC?
The system would have the necessary DC supply running off the 24VAC.
In irrigation units the DC current required would probably be minimal as it would be mostly for logic control of the solenoids.
35,071
The issue is not how much current the low voltage DC system requires. The concern is how much current the 24 VAC solenoids require. The supply voltage will drop if the power source is inadequate for the load.
My irrigation system is not connector to AC mains because it sits in the greenhouse with no access to AC power. It runs off of a 12 VDC SLAB (sealed lead acid battery). It does not use solenoids. It uses water valves that are driven by 3 VDC motors at less than 100 mA. The motor requires power only to open and close the valve which takes about 2 seconds to operate.
