MisterBill2
- Joined Jan 23, 2018
- 28,246
Actually, for small LEDs, it will worked to assume a target current of 20 mA and an approximate forward voltage of 2.5 volts. BUT the supply voltage must be known. With those numbers it is simple to calculate the resistance required to drop the difference between the supply voltage and the LED voltage at the nominal 20 mA current. Then take the next highest 10% standard value as the series resistor. This should be close enough since the supplier does not state ANY electrical details, such as switch ratings, current or voltage, nor LED ratings. Those details will need to be available if the project ever goes into mass production, because that supplier probably can not supply production quantities.
