220 motor wiring help
Drivero
Joined Dec 7, 2021
I am building a 2x72 belt grinder and purchased an Iron Horse 2hp AC motor and a vfd. Running 10/3 from the wall to the VFD then 12/4 from vfd to the motor.
I got all this wired up only to find that the 220 receptacle doesn't match the plug I bought. It's an Eaton Universal Angle plug 30/50amp 250v. Is there a different plug that can be wired on or do I need to change the receptacle to 3 wire? Can I wire a 4 prong plug with the 10/3 I already have? Not sure where to go from here.
ronsimpson
Joined Oct 7, 2019
4,795
Not certain what plugs you have.
In old house the dryers were wired 3 conductor. In new houses they are wired 4 conductor. (US & Canada) Then stove tops have a slightly different. ,,,,,,,,,,,,,,,,,
I usually change the plug on the tool or change the socked in the wall. It is also possible to find a adapter. I usually take phone pictures of the two pieces I have and go to the store and look to see what is available and for what cost.
What is in your wall is good because it has L1, L2, N and ground. Some devices only have L1, L2 & N or L1, L2 & ground.
MaxHeadRoom
Joined Jul 18, 2013
30,788
You can obtain a plug for that receptacle you have, you would just leave the neutral conductor un-connected.
Home Depot have them.
