20 kHz transformer secondary conversion to DC output
gluk69
Joined Oct 5, 2018
7
Hi everyone,
I'm trying to transfer a small power (few Watts) from a static coil to a rotating one, by feeding the primary coil with a pulsed squared signal @20kHz.
At the sec. coil output I'm measuring about 10.5~11 V but at the capacitor pins I'm getting only 4.6~4.7 V. What could be wrong? I think the frequency is appropriate to be handled by the diode full bridge formed by 4 1N4148, isn't it?Circuit.png
LowQCab
Joined Nov 6, 2012
5,102
What is a "Rotating-Coil" and exactly what is its relationship to the "Fixed-Coil".
Is there any type of Armature to concentrate the Magnetic-Field ?, or just Air ?
35,299
How are you measuring voltages?
I am going to hazard a guess that you measured 11V peak-to-peak at the coil using an oscilloscope. This would give about 5.5V peak value.
Subtract about 1V for the diodes would give 4.5VDC at the capacitor.
gluk69
Joined Oct 5, 2018
7
You have to think about two concentric coils in which the wider one is fixed and the other one is rotating around the winding axis inside the cylindrical space in the inner of the first one. They are separated by around 1mm air radial gap (no armature).
gluk69
Joined Oct 5, 2018
7
MrChips, you're totally right. So nothing wrong with the circuit but only in my mind :). This means only that I will have to rise the primary voltage. Thankyou
> There will be poor energy transfer with no means of concentrating the Magnetic-Flux in a useful manner
OP has not explained his experiment.
You would get bumpkiss from such a thing unless the coils were very well designed. how does the rotor cross B? what is B? The complaint of inefficiency means nothing without such information. I'm surprised you got anything. (I've tried hand wrapping transformers: they get next to nothing without design)
gluk69
Joined Oct 5, 2018
7
I ignore how much could be B, but I know how much power this system is able to transfer from stator to rotor circuit and I suspect it os sufficiente for my purpose.
I added some pictures below, hopefully more explicative than many words.
28,584
the diodes, 1N4148, are signal diodes. Try the system with a 0.47 mFD capacitor and no load. The coil resistance may be to high, and the power feeding the supply coil may not be enough.
28,584
If you can add a ferrite core inside the coils that will improve the power transfer without needing to modify what exists already. Unless that is where the bearings are located. The voltage doubler suggestion will increase the voltage but not increase the power..
gluk69
Joined Oct 5, 2018
7
MisterBill2 inside the inner coil there's the DC motor and in between the inner coil and the outer (static) one there's the air gap which is about 1mm thick radially. I think I'm running too short in room to achieve a ferrite core anywhere.
My hope is to be able to store more energy in the secondary circuit cap by means of an increased voltage after the diodes H bridge and not to transfer more power.
LowQCab
Joined Nov 6, 2012
5,102
"" My hope is to be able to store more energy in the secondary circuit cap by means of
an increased voltage after the diodes H bridge and not to transfer more power. ""
Power and "Energy" are basically the exact same thing,
possibly just in different forms.
Changing from one form of Energy to another always involves losses.
Transferring Power is the only thing that You are attempting to do.
( aside from wasting Power as Heat due to all the cumulative losses/inefficiencies along the way )
