2 x 18650 batteries in parallel to charge from one TP4056-C, than using both batts in series.
Status
Not open for further replies.
bowsprit
Joined Oct 2, 2018
52
I have made a stun gun (not for sale here), for my partner using a TP4056 , a 18650 bat, 2 switches, an LED and a 1000KV Boost Step up Power Module (Ex AliExpress)
Workings: One switch puts the voltage on the LED and connects to one pole of switch 2. On depressing switch 2, the "1000KV" is energized and a decent spark emanates from its 2 points. I works well.... it sparks well.
I read on line that these 1000KVunits , only reach around 10KV tops, That in my opinion is not going to do its intended job eg giving some attacker a good belt, without killing them.
I also read on this forum that one TP4056 can charge 2 parallel 18650 bats.
The 2 batts in series need to fire the '1000KV' which will increase the output maybe to 20KV or more, which i guess, would be sufficient to make a clean getaway when attacked.
BUT I am having a problem coming up with a simple circuit, with maybe some diodes or what have you.
Wonder if anyone could help?
WBahn
Joined Mar 31, 2012
33,316
MOD NOTE: This thread is being closed because it violates the User Agreement:
  • Restricted topics. The following topics are considered "out of bounds" and will result in your thread being closed without question:
    • Any kind of over-unity devices and systems
    • Devices designed to electrocute or shock another person
    • Jammers intended for actual use in other than legal academic contexts
    • Amateur/homemade rail guns and other high-energy projectile devices
  • If You come across a thread or post discussing any of the above topics please report the thread so We can close, and if necessary remove, the offending thread/posts.
In addition to that, your post and the kind of question that you are asking raises significant questions about your qualifications to design and construct such a stun gun. You need to ask yourself if you are really prepared to expose yourself to the potential civil and criminal liability that you are courting.
Status
