Protection between raspberry and 18650 batteries
sl4y62
Joined Jun 9, 2022
Hello everyone,
I have a raspberry 4b and I want to protect it from 18650 battery pack because i'm so afraid of damaging it with overcurrents or short current.
I'm not advanced in electronics although I drew a noob circuit (assuming that we are using two 18650 3.7v batteries as below)
1- I placed 3 LM1117 (5v voltage regulators) in series to get an output of 3A (each one has 5v - 1A output and 15v max input ) to supply the raspberry
2- Capacitors to stabilize current but I'm not sure about the value
3- Resistors to protect from overcurrent, not sure about the values too
4- And 1A diodes to prevent reverse current
dl324
Joined Mar 30, 2015
18,449
Welcome to AAC!
How do you plan to connect the regulator output to the 4B?
The diodes you show will prevent the Pi from receiving power. Why do you think you need 3 voltage regulators in parallel? Why don't you just put an external pass transistor on one?
Why would you ever want to have 3 batteries in series?
MrSalts
Joined Apr 2, 2020
2,767
Hello everyone,
Why not just buy a USB chargeable power brick?
Your diodes are backwards and I don't know which transistor pins you are using. What is the role of the resistors?
bassbindevil
Joined Jan 23, 2014
924
I'd use a 3S (12.6V) battery with a 5V car adapter, since I can buy those at dollar stores. I suspect that's more efficient than stepping up 4.2V to 5V in a power bank.
