Hi all, I have a 1949 Velocette LE motorcycle which uses a 6v DC POSITIVE GROUND electrical system. It has a 2 brush P. E.C DC generator putting out approx. 30 watt/5A charge(8-14v unregulated), as stated this is a positive ground system currently using the original shunt/cut-out type mechanical regulator which is past it's use by and impossible to find a replacement for. I can find somewhat expensive electronic replacements but would like to build my own. Any help on a suggested circuit would be really appreciated.
P. S attached pic is of the distributor/charge system, where you can see the old cut-out reg.
