2 Brush DC generator regulator circuit help
Dwayne Rothe
Joined May 26, 2016
12
Hi all, I have a 1949 Velocette LE motorcycle which uses a 6v DC POSITIVE GROUND electrical system. It has a 2 brush P. E.C DC generator putting out approx. 30 watt/5A charge(8-14v unregulated), as stated this is a positive ground system currently using the original shunt/cut-out type mechanical regulator which is past it's use by and impossible to find a replacement for. I can find somewhat expensive electronic replacements but would like to build my own. Any help on a suggested circuit would be really appreciated. :)
P. S attached pic is of the distributor/charge system, where you can see the old cut-out reg.
shortbus
Joined Sep 30, 2009
10,049
Is there a reason you want to keep the positive ground? That said on another forum ETO there is a thread where a member was making a regulator for an old 6V Volkswagen. He, with the help of the other members came up with an electronic solution that would fit in the original VW regulator case, so you might want to go there and look at what he did and why he did what it took to work. If I remember right his forum name is VWdan or something similar
schmitt trigger
Joined Jul 12, 2010
2,290
Even if you would like to keep the positive ground, with semiconductors you always have the option of complimentary devices.
If I remember correctly, in motorcycles the dynamo simply cuts out the field voltage when an over voltage is detected, and re applies it when the voltage drops
MaxHeadRoom
Joined Jul 18, 2013
30,885
If it use wound field control via a field interruption type contacts, you could possibly use a electronic version using a LM311 etc, this method was used to replace the mechanical interrupter type regulator in the old battery charging systems.
Max.
Dwayne Rothe
Joined May 26, 2016
12
Apart from not wanting to re-wire the electrics I would like to keep the bike as close to original as possible, it's not a daily rider so the 6 volt system is suffice for now, with that said I once was considering a retro fit electronic ignition/charge system and switching to 12V Neg. ground!
Dwayne Rothe
Joined May 26, 2016
12
YES that's correct, it use an electromagnetic core which opens and closes a set of contact points to apply/break the charge circuit which works but has it obvious weakness in the points wearing.
Dwayne Rothe
Joined May 26, 2016
12
Max.
Hmmm using an Op-Amp comparator circuit?
shortbus
Joined Sep 30, 2009
10,049
Other than switching the battery leads and re-flashing the generator I don't know what other rewiring would be needed. I'm not familiar with your make of bike, but I did the positive to negative ground thing on my 1957 Harley before I changed over to 12V.
Dwayne Rothe
Joined May 26, 2016
12
My only problem would be the charging system, the generator is built into the engines housing and only puts out 30W@6V so wouldn't successfully supply enough charge
shortbus
Joined Sep 30, 2009
10,049
No, I didn't mean to change to 12V. Keep it 6V but just change the ground to negative. Then you coulld keep it looking like original and use a easier to find regulator. You when changing ground polarity would need to "flash" the generator to establish the new polarity, just like putting a new generator on the motor.
Dwayne Rothe
Joined May 26, 2016
12
No, I didn't mean to change to 12V. Keep it 6V but just change the ground to negative. Then you could keep it looking like original and use a easier to find regulator. You when changing ground polarity would need to "flash" the generator to establish the new polarity, just like putting a new generator on the motor.
Sorry I misread that. Well yes as you pointed out,it is not that difficult to achieve just might be the easiest solution. Thanks :)
