djsfantasi
- Joined Apr 11, 2010
- 9,237
Could you dedicate a SPDT set of relay contacts to the other indicator? A DPDT set of contacts would reduce this to a trivial exercise.
I'm using a SPDT relay. The other set of contacts are used for a voltage control. Would I need to use two relays?Could you dedicate a SPDT set of relay contacts to the other indicator? A DPDT set of contacts would reduce this to a trivial exercise.
A couple of transistors probably work out cheaper than upgrading to a DPDT switch.All that's needed for that is a ground. The transistors serve no useful purpose.
That seems to work, but I have 3.5 VDC at the LED. Is that too much?Change the 82 ohm to 330 ohms.
Move the transistor grounds to the right side of the bridge rectifier.
Change the base resistors to 680 ohms or so.
Don't forget ground for your meter is now the right side of the bridge.That seems to work, but I have 3.5 VDC at the LED. Is that too much?
That's near right for blue and white LEDs. Green LEDs; expect 2.0V or thereabouts, Red LEDs come in around 1 3/4V.That seems to work, but I have 3.5 VDC at the LED. Is that too much?
there was never a need for the transistors.This way there are no transistors.
There is a constant flow of current when the relay is switched on. When it is switched off the only current flowing is for the LED. I'm not sure how it could be more efficient?there was never a need for the transistors.
your approach is also inefficient: there is a constant flow of current from the ground / rail. it can be made a lot more efficient.
I'm not clear on the 2 ground symbols. Is there a reason for that?There is a constant flow of current when the relay is switched on. When it is switched off the only current flowing is for the LED. I'm not sure how it could be more efficient?
The SPDT switch is part of the relay?View attachment 113764
Here is a more complete schematic. The relay shows only one side, and there are two circuits that it switches. I was a little confused about where I was finding the voltage. I went and spent some more time studying, and these are correct voltages. The two 100 ohm resistors used to go straight to ground, but I've had to do some ground referencing. Now the LED won't work. Sorry about the earlier posts.
Yes.
The two ground symbols only mean that the current flows through the LED to ground from the opposite B+. I haven't built one with this design in this circuit yet. I know that it works, because a built it in a variation on the circuit that I'm going to use. The problem is that I'm getting a much higher reading for the forward voltage. I made a DC filament supply and tried it. The circuit I've shown uses an AC filament supply.I'm not clear on the 2 ground symbols. Is there a reason for that?
There is no voltage shown in your circuit.
I bet you are.The two ground symbols only mean that the current flows through the LED to ground from the opposite B+. I haven't built one with this design in this circuit yet. I know that it works, because a built it in a variation on the circuit that I'm going to use. The problem is that I'm getting a much higher reading for the forward voltage. I made a DC filament supply and tried it. The circuit I've shown uses an AC filament supply.
