16025 Transistor
Redtruck80
Joined Jun 3, 2024
Hi, I am after a bit of help if possible please, I have some old voltage regulators off of lorries and they use a 16025 , I can't seem to find them, assume they are obsolete, is there an equivalent? Photo attached.
Thanks in advance
Ian0
Joined Aug 7, 2020
13,131
Most of RCA transistors on general sale started 40xxx. I suspect it may be a "special", but it's just a bipolar transistor so isn't really that special.
If you can identify whether it is NPN or PNP, or whether it is a Darlington, then it should easily be possible to identify a replacement.
What is the spec of the regulator? Input voltage, output voltage, maximum current?
(My guess is that it will be a standard NPN bipolar transistor and that you could replace it by a 2N3055)
