12vdc to 15vdc oscillator
Kaash58
Joined Oct 8, 2023
I need oscillator design which can convert 12vdc to 15vdc 2to4amp which must include chopper and better if it includes UC3843 ic
AnalogKid
Joined Aug 1, 2013
12,284
That is not the best part for the job. Is this school work?
The datasheet and app notes have examples only of off-line isolated converters. Since what you are after is a non-isolated boost converter, there are other parts designed specifically for this. Consider the LT1270A.
ak
Papabravo
Joined Feb 24, 2006
22,113
An oscillator, by itself, will not do the job. What you need is a boost converter, which is a type of SMPS (Switch Mode Power Supply). A very good starting place will be Hart, Daniel, Power Electronics, Chapter 6. It is available online as a freely downloadable ebook.
Before you get started, you must know the immutable rule of ALL power conversion schemes, and it is this:
The power output will always be less than the power input. Sometimes it will be much less.​
15 VDC @ 4 Amperes = 60 watts. Assume for the sake of argument that your boost converter is 80% efficient (a reasonable target for your first design). The required input power will be 60 watts / 0.8 = 75 watts, and 75 watts from a 12 VDC supply will require 6.25 Amperes of current. Your boost ratio of 1.25 is certainly reasonable.
Careful layout, fabrication, and assembly of the PCB will be essential to the success of your project.
Kaash58
Joined Oct 8, 2023
No one read my question carefully everyone suggest me to use booster circuit which i didn't need. I was in need of oscillator circuit.
Any how my problem is solved and i build it by myself,
Thanks All.
Papabravo
Joined Feb 24, 2006
22,113
Thanks All.
I think you are off the mark here especially since you indicated the use of a UC3843, which is specifically designed for use in boost converters. That said you are completely entitled to inhabit your own personal reality if you think an oscillator can perform the function you described.
DC_Kid
Joined Feb 25, 2008
1,242
Current - Output (Max)67mA, 67mA
I don't think a 30 V, 67 mA device meets a 15 V, 4 A requirement.
Look at the size of the package, and think - is 632 watts per cubic inch really possible on this planet, and for less than $6 - ?
ak
Yeah, odd, it has "15v output" and "60W" listed in it's specs.
So yeah, specs must be wrong.
Sorry, didn't look deeper into the other "67mA" specs.
