chattering relay with magnetic reed switch (12VDC) problem.
wwdwgs
Joined Mar 11, 2025
23
I'm confused with the electrical issue I have on my car.
This is a situation:
1 - originally, the gas strut (hatch) is "wired" and acts as a light switch: when the hatch is closed, the strut is compressed, the circuit is open - no lights.
2 - when the hatch is open, the gas strut is extended and the contact is made to complete the circuit - the light is on.
3 - I had to remove this strut, so I needed to find another way to trigger the light.
4 - I ran a magnetic reed switch NO (normally open) when the magnet is next to it.
5 - the magnet moves and the reed switch closes the circuit - the light is on.
Simple in theory, but... This reed switch gets stuck after it's on for more than a few seconds. I assume that it "burns" and its contacts "weld" together. This reed switch is rated 0.5A 12VDC.
So, I added a relay, 12VDC, 1A, so the reed switch activates the elec. magnetic coil in relay and the relay completes the circuit, carrying more amperage.
I bench-tested this set up using scooter's 12V battery, relay, reed switch, light and wires... all works well - as intended.
When I installed this set up on the car WITH REED SWITCH POWERED SEPARATELY FROM CAR'S WIRING (USING SCOOTER'S BATTERY), the light tuns on. All works as intended.
BUT... when I power the reed switch from the car's circuit, shared by the relay switch and the light, the relay starts to buzz or chatter. Adding a 470mF capacitor in parallel with relay coil terminals "slows" the rate of chattering. 2 capacitors in parallel slow it even more. I thought that reed switch doesn't pass enough current (amps) to keep the relay's coils "closed".
then... I tried to use a different relay, about 0.2A 12VDC - same problem.
What am I doing wrong?
I tried different resistors, all they do is dim the light, but chattering remains.
What do I need to do to fix this problem? and how?
wwdwgs
Joined Mar 11, 2025
23
This is a crude schematics. The "block" with a question mark in it designates other wiring, door switches and dome lights, that must be in that circuit. The same layout without "?" block works fine on the bench.
sghioto
Joined Dec 31, 2017
8,756
You have the relay contact shorting out the relay coil and reed switch when activated is the problem.
Connect the top side of the relay coil to +12 volts only.
wwdwgs
Joined Mar 11, 2025
23
Hm.. that would mean that I have to run a new wire to, let's say, a fuse "+" (within dome lights circuit).
Is there a way to "restrict the flow" and prevent interference between the load and coil sides of the relay? Diode? The reason I ask is that I'd like to avoid more wires in the car. I'm not an electrician and don't know much about it, so, forgive me, if my questions "sound' stupid. What do you think?
wwdwgs
Joined Mar 11, 2025
23
So, why did this set-up worked on my bench with single power source? This bench set-up is the same, except that "mystery" box with "extra components"?
vu2nan
Joined Sep 11, 2014
357
Here's the correct schematic.
The flyback diode is required to prevent reed switch damage by inductive kickback from the relay coil.
Nandu.
sghioto
Joined Dec 31, 2017
8,756
Exactly, one side of the relay and the lamp are connected to 12 volts as I posted earlier.
In the car you are trying to power the relay through the lamp which won't work as you know.
wwdwgs
Joined Mar 11, 2025
23
Nandu, from your schematic I understood that I placed the reed switch "from neg. side", yours is "on pos. side". I can change "the sequence" no problem. So, what is this diode? What are its specs?
sghioto
Joined Dec 31, 2017
8,756
Don't need to change the switch orientation.
Talk about the diode later.
