I am wondering if there is a device on the market capable of providing a constant 12V DC for a 240W motor? The largest I can find is a 10A voltage stabiliser. The issue we are having is that when the engines are running on the boat, the output voltage increases and if someone uses the toilet, the pump operates at a greater RPM, which has caused the belt to slip and break on a couple of occasions.
If someone can think of a better solution or knows of such a device, that would greatly appreciated.
Thanks in advance,
Stuart
Thanks in advance,
Stuart
