hi everyone, this is a long shot but here goes. My son was handed down an old Kid Trax 12V ride on car but I dont have power getting to the wheels when the foot pedal is depressed! I've verified the battery has 12.5v getting to the board. There is a gear selector that I've taken apart and cleaned and tested for continuity between the contacts (all fine).
When the key is turned on, all lights work. Putting the gear selector in reverse and depressing the foot switch only makes the relays click...no movement from the motors in the tires. (Motors work by direct connection to the battery). 1st gear selector makes relays click....again no movement. 2nd gear selector cause relays to click and after 2 seconds one tire attemps to spin but it cuts out almost instant.
I've removed all 4 relays from the pcb and tested each one and all 4 open/close when supplying 12v to the coils.
My question is what could fail on this pcb that provides 12v to the motors when the foot pedal is depressed.
Thank u so much!
Thank u so much!
