12V LED light timer circuit
Wolframore
Joined Jan 21, 2019
2,619
I’m confused and a little disappointed with the kit. The whole point of it is it’s supposed to have 3 @ 5k resistors for the divider. They used 4.7k. Why... simple fix but it’s also printed on their board. Plus visually I would have place them vertically like the trigger and threshold. Maybe there’s a better version out there.
Wolframore
Joined Jan 21, 2019
2,619
See all the cool things we learn here? I suppose the voltage divider values doesn't matter as long as the current is kept in check. I wonder if Art Fury made the correlation non the less.
12,130
The magic of the 555 is that while the absolute resistor value tolerance is relatively terrible, the ratio and temperature tracking are excellent. A line in the original product release said the device "contributes less than 1% error" to the output frequency or pulse width. This was significantly better than its only competitor at the time, the 74121. Plus it had a much wider operating voltage range. Plus it had that extra-beefy output stage. Love at first sight.
Poc777
Joined Apr 26, 2019
2
Hi guys
I have problem with my abs sensor light on my 00 Jeep
Sensors cost 250 each Jeep worth about 1000
Any circuit I can use to switch light off after 3 seconds
There is a bridge in the diagnostic plug that when I take it out light goes off
Anything that I can use instead of this bridge
Wolframore
Joined Jan 21, 2019
2,619
Have you tried cleaning it (the sensor)? And check the wiring for wear. For some reason sometimes it’s cheaper to change the hub bearing which comes with a new sensor.
12,130
Hi guys
I have problem with my abs sensor light on my 00 Jeepe
It is considered bad form to hijack someone else's thread. If you have a question about something automotive, there is a forum for that.
Also, your question is sorely lacking in detail. for those who don't speak car:
What is an abs sensor
What are the sensor output characteristics
What light
What bridge
What plug
