555-timer circuit to turn on light for 1 hour
rayrivera
Joined Mar 22, 2017
10
Hello folks, I hope you are all doing well. I would like some help finishing this project. The goal is to build a circuit that turns an led light ON for an hour with one tact switch for a button. The project is currently built with a 555 timer and two buttons. The 555 ic pictured needs a min of 4.5v so I will need to find on with a lower min input. It needs to run off of a 3v button cell battery. I am new to electronics but need to get over the hump. Thank you for any help and guidance.
atferrari
Joined Jan 6, 2004
5,029
Learnt how to properly title a thread and post a schematic or a block diagram at least.
OBW0549
Joined Mar 2, 2015
3,565
Instead of a 555, use the CMOS version such as a TLC555; it will operate on 2-15 volts so should work well off a 3V cell.
It's good practice to give your posts a descriptive title that at least gives a hint as to your topic; "First time posting" doesn't tell anybody anything.
AnalogKid
Joined Aug 1, 2013
12,281
An hour is a looooong time for an R-C timer like a 555. If you must use it, go with the CMOS version as above. If you can change, consider a CD4060 circuit. This is a combo oscillator and divider chip and is much better for long time periods.
Here is an example from another thread. How bright does your LED have to be?
ak
rayrivera
Joined Mar 22, 2017
10
Thank you for the gentle suggestion about properly naming my post. I will attempt to fix it and name them accordingly in the future.
38,855
I agree with AK.
An hour is a long time for a 555 time.
Use the circuit he posted instead.
But the 0.33μF cap across the PB switch can fry the contacts due to the high surge current.
Put a 100Ω resistor in series with the switch to limit the current.
rayrivera
Joined Mar 22, 2017
10
ak
Thank you, white color and medium brightness.
rayrivera
Joined Mar 22, 2017
10
That TLC555 is going to be my next purchase, thank you.
Sensacell
Joined Jun 19, 2012
3,789
You will find the "1 Hour" to be totally unstable and unpredictable with a single stage RC timer - like the 555.
Proceed along this path if an "hour" can be anything between 20 and 90 minutes.
If that's not ok, then you will need another design approach.
How precise the timing needs to be is an important design parameter to specify.
