Floating output are almost always acceptable, so Q4-Q9 can be left unconnected. It is floating inputs that can cause erratic circuit operation and component failure.
An exception is the "AC" series, which can source and sink 24 mA (but not all outputs simultaneously, and there still is a significant output voltage drop).
The power dissipated by the LED is not the immediate issue. CMOS output transistors, even the more beefy "B" series parts, are not designed to drive much of anything except other CMOS inputs. That your parts have survived is due more to luck than physics. never include design margin in good design practice.I believe you have to do a power calculation and you will see that it's under the power limit of the LED in the buffered cases.
