12 volt regulator drops for 12 volt dc motor
LowQCab
Joined Nov 6, 2012
5,102
1-Volt at 1.5-Amps = 1.5-Watts of HEAT that must be dissipated.
12-Volts at 1.5-Amps = 18-Watts of HEAT that must be dissipated.
12-Volts at 0.5-Amps = 5-Watts of HEAT that must be dissipated. ( probable start-up-Current for your Motor )
12-Volts at 0.25-Amps = 3-Watts of HEAT that must be dissipated. ( maximum continuous-Current allowed for your Motor )
Does your Regulator have a Heat-Sink that can easily dissipate at least ~5-Watts of HEAT ?
A TO-220 Transistor-Package,
with no Heat-Sink,
can "usually" dissipate around ~1-Watt of HEAT,
before getting TOO-HOT and smoking the device inside.
Your Regulator will automatically shut-down if it gets too HOT, ( if you're lucky ).
Please describe the Mechanical-Load that your Gear-Motor is having to accelerate,
and any drag that it must overcome.
DickCappels
Joined Aug 21, 2008
10,661
Or maybe better yet, try improving your heatsink or even better power your 7812 from 15 volts and see if that solves your problem.
