12 volt regulator drops for 12 volt dc motor
chandimajaya85
Joined Sep 27, 2023
41
I have a DC motor connected to a 12V DC power supply from rectifier. Sometime the load increases than usual and motor RPM reduces. This in turn makes a voltage drop in the power supply something 11.97 to 11.89 volt. Then the Motor stops. Any idea why the motor stops.
bertus
Joined Apr 5, 2008
23,029
Are there details on the motor, like a datasheet.
It could be that the motor takes to much current and the regulator shuts down.
Bertus
ericgibbs
Joined Jan 29, 2010
21,643
Hi c85,
The 7812 can dissipate approx 2Watts without an heat sink.
From a 24V supply, this means the maximum allowed current would be 2W/12Vdrop = 0.165Amps.
So I suspect the 7812 is going into thermal shut down as the motor current draw is exceeding say 0.2A.
E
28,576
It is entirely possible that as the load on the motor increases and the resulting power draw current rises, that the current exceeds the capability of that " 12V DC power supply from rectifier", and that supply voltage switches off.
Since we have no description of that power source or it's capability, I have no basis for any additional comments about it.
DickCappels
Joined Aug 21, 2008
10,661
I think that the 7812 going into thermal shutdown is an excellent candidate. After the motor shuts down, how hot is the 7805 (actual degrees C would be helpful too, but a subjective evaluation may be enough "It is hot enough to fry spit" to "It hurts to keep my finger on it" to "about room temperature, etc.)
LowQCab
Joined Nov 6, 2012
5,102
It would also help to have a complete, detailed description
of the Mechanical-Load that the Motor is expected to deal with.
~12-Volts is entirely too much Voltage to be dropped across any Linear-Regulator.
A PWM-Current-Regulator would be the best way to control and protect the Motor at the same time.
More details are needed on the Power-Supply, even if not using a Linear-Regulator.
How big are the Filter-Capacitors ?,
if practical, a Choke-Input-Filter on the Power-Supply would be even better.
chandimajaya85
Joined Sep 27, 2023
41
Hi c85,
E
But, I looked at the datasheet of the L7812CD2T-TR, it can handle of up to 1.5A. Attached the data sheet of L7812CD2T-TR. The motor part number is MG16B-060-AB-00 (DC 12V). I dont think it is not capable of handling the motor current draw. What do you think about this.
chandimajaya85
Joined Sep 27, 2023
41
Datasheet of the L7812CD2T-TR (12V Voltage regulator), it can handle of up to 1.5A. Attached the data sheet of L7812CD2T-TR. The motor part number is MG16B-060-AB-00 (DC 12V). What do you think about this.
ericgibbs
Joined Jan 29, 2010
21,643
Hi c85,
The motor start current is ~0.8A, so with a 24V input to the 7812 regulator, that gives for the 7812 dissipation 12V* 0.8A =9.6Watts!!!
Look through these clips from the datasheets, I would say again the 7812 is going into thermal shut down at motor start up.
E
E
DickCappels
Joined Aug 21, 2008
10,661
What you also need to take into account is the temperature of the die.
The fact that you can get the motor started but it cannot recover from a stall strongly suggests that, as ericgibbs noted, the problem is thermal shutdown.
Without going through more math exercises it seems quite clear that when the motor stalls it draws more current, causing the power dissipation of the die to increase, pushing the die temperature to the point that the chip goes into termal limiting.
Some things you can try are:
Reduce the voltage going into the 7812,
Difficult but often effective is to shunt some current around the 7812, such as by placing a resistor from the input to the output. You need to pay attention to the power rating of the resistor because you will be moving some power dissipation from the 7812 to the resistor.
Improve the heatsinking buy using a more efficient heatsink and/or fan.
Those are your best choices. A poor solution would be to add an external pass transistor, because that brings in complications such as current limiting but you might end up doing that because of circumstances not noted here.
Try reducing the temperature of the 7812 and you will probably be able to move beyond this problem of a motor stall locking the motor even after the cause of the stall is removed.
BobaMosfet
Joined Jul 1, 2009
2,211
Motors aren't driven by voltage, they are driven by current- you have insufficient current. When motor stalls, you're shorting the battery through the motor
chandimajaya85
Joined Sep 27, 2023
41
LowQCab
Joined Nov 6, 2012
5,102
What is the Mechanical-Load on the Motor ?
What is it expected to do, and how fast ?
What is the Weight of the Load, and how BIG is it ? , a picture would help a lot.
