12 volt current amplifier
NimaMaster
Joined Aug 3, 2023
42
Is it possible to add a detection system for when the detector itself fails or loses power? If these were to happen, the low voltage the detector outputs when it's in normal mode would be completely cut off. A circuit that detects the absence of that low voltage and powers the relay would make it much more secure.
sghioto
Joined Dec 31, 2017
8,765
Not sure what you mean. If the detector drops out so does the relay. If another circuit detects the absence of the low voltage and powers the relay why would you need the detector to begin with?
NimaMaster
Joined Aug 3, 2023
42
The relay is connected to the security system in a normaly closed config and is not active normaly. It activates when the detector senses smoke thus cutting the circuit on the security system's side sounding the siren. The flaw with it right now is that if the detector fails the system won't see that and not react to smoke and you can't know that unless you regularly test the detector. I want it to also activate the relay when the detector fails so i would know to replace the detector.
sghioto
Joined Dec 31, 2017
8,765
That is the standard procedure for knowing the detectors are working properly.
The only thing I see on the detector that might work is monitoring the function of the Green LED.
It says the LED flashes when operation is normal.
How often does it flash exactly?
NimaMaster
Joined Aug 3, 2023
42
Yes, the LEDs flash subtle green every 10 to 20 seconds and that would be an indication of the detector's health. However my concern is that it fails when I'm away from the location. There are times I'm away for a few days and can't physically check the detector.
sghioto
Joined Dec 31, 2017
8,765
I have a simple timer circuit that can be connected to the existing circuit to activate the relay if the green LED fails to flash at least say in 30 seconds. It involves mounting a LDR or Light Dependent Resistor on the detector.
The circuit is shown inside the gray box.
AnalogKid
Joined Aug 1, 2013
12,301
Even with a min gain of 130, the C945 (Q1) probably will not be firmly saturated with only 1 mA of base current. Consider reducing the value of R2.
ak
