12 volt current amplifier
sghioto
Joined Dec 31, 2017
8,765
From various attempts to get the circuit working it did indicate that was the issue but it could have been defective transistors. I should have asked for more voltage readings initially.
NimaMaster
Joined Aug 3, 2023
42
I also now believe that the Transistors were defective but an opto makes sense in this case. The detector has an isolated voltage through two pins as the output. when the negative output is grounded it just takes 12v from power supply and activates the relay. when it's not grounded it's an open loop. my mistake was that I didn't paint the whole picture and the detector's pinout was out of the equation for quite some time.
erintse
Joined Aug 16, 2023
Have you tried the circuit like this?
+12V
R1
| R2
| +----- Relay Coil
+---B---| NPN Transistor (e.g., 2N3904)
| E
GND GND
NimaMaster
Joined Aug 3, 2023
42
I just finished making another one for a second detector, then i got an idea. Couldn't we have just used the opto and the 4.7k resistor to achieve the same result? Pins 3 and 4 on the opto close the circuit when supplied with voltage on 1 and 2.
